say im going 40 mph and it will just go on tick over my mph needle drops to 0 but im still rolling but it still revs but nothing then it just kicks in again has anyone else had this problem
good to go!!
| Author | Subject: when driving engine does accelerate |
calumsaddler
Junior User Location: wakefield Registered: 02 Sep 2013 Posts: 66 Status: Offline |
When im driving my engine just stops it doesnt die but goes into tick oversay im going 40 mph and it will just go on tick over my mph needle drops to 0 but im still rolling but it still revs but nothing then it just kicks in again has anyone else had this problem ________________________________________ good to go!! |
gman
Seasoned Pro Location: Didcot Registered: 25 Oct 2007 Posts: 1,471 Status: Offline |
Sorry, but what you have said doesn't really make any sense. Perhaps restructure your sentence and someone maybe able to help.Are you saying that your engine and rev counter are working fine, but that your MPH gauge stops working on occasion? ________________________________________ 1992 Onyx Black 205 GTI-62005 Honda S2000 (Sold) 2002 Audi S3 (Sold) 2005 Clio 182 Trophy (sold) |
doon1988
Regular Location: Sheffield Registered: 08 May 2011 Posts: 457 Status: Offline |
If you mean what gman says then it could be your VSS (speed sensor) that needs replacing. Mine does this on and off whilst im driving. Ive purchased a new speed sensor but haven't fitted it as yet but i've heard its a good place to start. |
bennn
Seasoned Pro Location: Shrewsbury Registered: 05 Sep 2008 Posts: 2,705 Status: Offline |
calumsaddler wrote: When im driving my engine just stops it doesnt die but goes into tick over say im going 40 mph and it will just go on tick over my mph needle drops to 0 but im still rolling but it still revs but nothing then it just kicks in again has anyone else had this problem Try and make a bit more sense mate. If you are saying your speedo is dropping to 0 and then kicking back in again, then its most likely the VVS sensor on the gearbox. If you are saying you'll be driving along and the engine, is misfiring or cutting out, its probably likely to be a sensor of some sort (MAP Sensor, TPS, ICV) ________________________________________ Cherry Red 306 HDIChampionship White Integra DC5 Type R |
doon1988
Check this thread for some info if your issue is what we expect about the speedo dropping:http://www.306gti6.com/forum/showthread.php?id=145549&page=1 |
calumsaddler
Sorry guys was in work. Yes basically ill be driving and the car will run smooth. Then randomly the engine will jolt thats when the mph needle will drop to 0 and it feels like the engine is on tick over but obviously im still moving I can still rev the car but it doesn't accelerate then suddenly just starts working again!! Bit confused haha sorry about my sentences im a Yorkshire man !! ________________________________________ good to go!! |
calumsaddler
calumsaddler
pete-gti
Seasoned Pro Location: Kent Registered: 15 Feb 2009 Posts: 1,297 Status: Offline |
So it dropped to 0mph, car revs still but doesn't move?, clutch? |
Seasoned Pro Location: Parts for Sale section Registered: 04 Dec 2007 Posts: 7,442 Status: Offline |
Sounds like its going into neutral. Not sure if the speedo goes to zero though, never really tried myself.I have no idea what the issue is, but then I still dont fully understand what you are explaining ![]() ________________________________________ Chris1999 China Gti6 Supercharged [Fun car] >>Project Thread<<2000 Bianca 306 Diesel [Work runabout] |
calumsaddler
No when im driving. say ill be going 40mph it will do it then needle drops to 0 but car still rollsengine feels like its on tick overi can still rev it but it doesnt do nothing then randomly goes back to normal mate ________________________________________ good to go!! |
pete-gti
If cars still revs , got be clutch ? |
calumsaddler
Ive just had a new 5 plate ceramic paddle clutch in few month ago:/ I was going back to work last night and I noticed I could get up 100+mph fine but when I let off acceleration it feels like its bogging out ive put it down to either vvs sensor like you guys have said or its misfiring from plugs or spark leads but I could be wrong ________________________________________ good to go!! |
Not a clue________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
bennn
calumsaddler wrote: Ive just had a new 5 plate ceramic paddle clutch in few month ago:/ I was going back to work last night and I noticed I could get up 100+mph fine but when I let off acceleration it feels like its bogging out ive put it down to either vvs sensor like you guys have said or its misfiring from plugs or spark leads but I could be wrong I doubt it would be the VSS as this doesn't cause running issues in itself. My money would be on a map sensor, although this wouldn't cause an issue with the speedo. You could try driving it with the MAP sensor disconnected and see if there is an improvement. ________________________________________ Cherry Red 306 HDIChampionship White Integra DC5 Type R |
calumsaddler
Hmm never thought of that ill give that ago its located behind the battery isnt it ?________________________________________ good to go!! |
bennn
Its on the inlet manifold mate.________________________________________ Cherry Red 306 HDIChampionship White Integra DC5 Type R |
woody.
Senior User Location: London Registered: 18 May 2009 Posts: 806 Status: Offline |
The car won't run with the map sensor disconnected...Could be a lambda issue, unplug the lambda plug in the engine bay and reset the ecu (battery disconnected for 5-10mins) and give it a run to see if anything's improved |
jimmyhackers
Seasoned Pro Location: birmingham Registered: 14 Jun 2011 Posts: 1,302 Status: Offline |
perhaps somethigns gotten inside your engine bay...?thats far more likely to happen when your bonnets been removed ![]() ________________________________________ the world is changed by people in sheds |
Cjwatson27
Mine done this recently it just dies but don't cut out . I found my gearbox earth had come loose , I've relocated it now and it hasn't done it since ________________________________________ Old pugs don't die they just get faster |
