Author Subject: fitting the walbro 255 pump
pete-gti
Hey guys I'm fitting the walbro 255 pump into the original pump housing, I need little help I want to make sure I get it right,
Here's the old and new pump
I see how rich fitted the top in this picture
But its the bottom I'm not how it goes, and its different to the standard pump, any help with be very much apprecaite
Posted 27th Jan 2014 at 15:32
i did my 205 gti one recently with a walbro one, probably the same, and it's got a load of circle rubber inserts / mounts which you mount the bottom of the pump onto (part of the old 205 gti pump assembly), then the pickup goes at the end obviously. should be fairly straight forward Unsure
Posted 27th Jan 2014 at 15:52
pete-gti
Not really , wouldn't have any pictures?!
If its to difficult I'll just scrap the idea, but I'm sure someone must of fitted one?
Posted 27th Jan 2014 at 16:40
pete-gti
My standard pump went and my mate had this one, but think standard walbro pump I'm going have to buy, shame but looking to much hassle,
Posted 27th Jan 2014 at 18:44
pete_rallye
Don't do it. In the bottom of the pot is a non return valve which you almost certainly have to remove to get the pump to fit. The non return valve stops the fuel leaving the pot under cornering so you don't get fuel starvation, if you remove it the pot empties in seconds and you'll get fuel starvation. I did eventually get one to work but I had to drill the side of the bottom of the fuel pump, and used a bit of copper pipe sleeve, a hose clip and a bit of alloy pipe to make a pipe inside the pot from the new pump, and I only did that because I had qualifying the next day, otherwise I wouldn't have bothered... Save yourself some heart ache and wasted money, run the standard fuel lines into a swirl pot and a higher pressure external pump from there.
Lap of the 'ring
Posted 27th Jan 2014 at 20:40
mabgti
NV motors
I went through all the hassel too.. Even had machined fittings and spacers. But still got fuel surge on hard accel and cornering.
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 27th Jan 2014 at 20:47
pete-gti
Cheers guys I will scrap that idea, swirl pot and pump then :-)
Been looking for standard pump, mines the walbro erj 237 , keep getting the walbro erj 197 coming up is this the same pump ?
Posted 27th Jan 2014 at 20:55
this is what i got:
http://www.ebay.co.uk/itm/160822661118
"Walbro GSS340 255 LPH - High Pressure IN TANK Fuel Pump With Filter Element"
this is on a 205 gti mind you, but i did not notice any differences whatsoever and nothing from the pump was removed that would aid surge. everything aside from the pump remained the same
Posted 27th Jan 2014 at 21:12
pete-gti
Bottom of the pump housing hole is smaller, on that pump looks big hole on bottom?,
Can anyone else let me no if that pump Ricky has said would work?
Posted 27th Jan 2014 at 21:18
loads of people on the 205 drivers site using them, that's how i found it infact
that said, mine's a standard gti6 engine / 205 tank. not supercharged or anything
Posted 27th Jan 2014 at 21:59
pete-gti
205 pump housing might be different
You haven't got any pictures of fitting it?
Posted 27th Jan 2014 at 22:08
this is what i have:
http://www.rikky.net/upload/205gti-j338vwk/pump1.jpg
http://www.rikky.net/upload/205gti-j338vwk/pump2.jpg
is yours just not an inline one rather than a proper pickup one?
Posted 28th Jan 2014 at 15:34
pete-gti
Yours is different have a look at my top picture, it want fit in hole at bottom of housing the 255 is ofset
Posted 28th Jan 2014 at 16:06
hmm not sure, the pumps look entirely different anyway, maybe the 205 gti one is an easier configuration for the walbro pump (or the one i've got)
Posted 28th Jan 2014 at 16:21
pete-gti
Your setup want fit in mine, different connections, shame it isn't straight swop could of put your style in
Posted 28th Jan 2014 at 16:56
