$1,800
1991 Peugeot 205 *Gti-6 Track Car*
  • 2000cc
  • Grey
  • 0 miles
  • No tax
  • No MOT
  • Service history unknown
  • Cambelt changed: Unknown
Modifications: Loads
Contact: 07736249881
Author Subject: 1991 Peugeot 205 *Gti-6 Track Car*
Jake
Allo,
For sale is my Peugeot 205 track car running a 306 2.0 Gti-6 (167bhp) engine. I bought this car in 2012 and spent some time cleaning it up and painting various bits and getting it ready for more trackdays, unfortunately I only managed a handful due to other commitments (Racing mx-5s Big grin) so this is now up for sale.
The car currently has no TAX but is MOT’d until April, I can tax it if requested but I haven’t driven it on the road for about 6 months so couldn’t comment on how it drives. I would recommend to trailer it away as the tyres aren’t legal (lots of tread but scrubbed off inside edge, still good for trackdays).
The bodywork is in good condition for a track car but has picked up a few scratches being in the garage. Engine is very strong and you won’t be disappointed! Handling wise I ran this on yoko A048s and was very impressed with the grip and the other cars it could keep up with and pass! It’s a very capable lightweight track car!
The spec is as follows:
Engine:
2.0 306 gti 6 engine
6 speed box
Re angled manifold (engine at correct angle)
Solid mounts
Quick shift modified linkage with mi16 stick and reverse cable
Larger 309 gti radiator lowered to allow room for inlet
Twin cooling fans on a switch (one fan still kicks in as normal)
Uprated cams ( according to engines last owner) so sold as standard due to no proof
unlocked gti6 ECU
Bespoke alternator setup - no AC
Pulls very well right upto limiter and the ratios of the 6 box really suit track driving.
Spiky (off the 205 drivers forum) engine loom
Re angled down pipe and full magnex exhaust system
Drivetrain:
Bilstien shocks and springs
Polybushed 309 gti wishbones and 309 gti driveshafts
205 gti 1.9 hubs with
Drilled grooved 206 gti180 discs and calipers
Drilled rear discs with new pads
BRAIDED HOSES ALL ROUND
New brake pipe and brake bias mounted by handbrake
Beam fully rebuilt a few years ago
Solid alloy rear mounts
Poly bushed
New drop links
309 gti ARB
1.9 wheels with Toyo Proxis T1R's (seen one trackday so at least one left in them)
I’ll throw in a set of black 1.9 gti Speedline alloys with yoko A048s (only 1mm tread but good enough for another trackday)
Steel grey 1.9 gti shell - rust free and still in pretty good condition
Aluminium plated sunroof, polycarbonate rear screen and rear quarter windows (kept wind up fronts), Skoda Fabia front splitter, stripped out heaters and new dash panel with battery cut off and battery relocated to boot, aero catch locking bonnet pins, locking boot pins, and some general lightening
10 point OMP roll cage with extra harness bar
Single bucket and 4 point harness
Gti passenger seat and 3 point harness that I put in for MOT
Bad points:
Speedo doesn’t work (due to snapped cable)
No rev counter (needs wired up)
Could do with a cambelt change before next trackday
Price is £1800
Contact me by email: simpson_ad100@hotmail.com
or give me a text on 07736249881
Cheers,
Jake
Pics:
Advertised here first because I love yous all.
The 205
205 GTI6 For Sale
Off Racing!
Posted 24th Jan 2014 at 21:20
JWP EFi
Turbo Legend!
I had a wee look at this couple weekends ago with Chris, its well put together, ideal ready to run track toy, good luck with the sale Jake
Posted 24th Jan 2014 at 21:24
Jake
Cheers Seb
Bump!
The 205
205 GTI6 For Sale
Off Racing!
Posted 28th Mar 2014 at 12:13
£1083? Bargain!
Good luck with the sale Smile
Posted 28th Mar 2014 at 12:21
superchargedblack1997gti6
Why are you so far away!
Posted 28th Mar 2014 at 12:29
eddy_gti6
Great handling car and very quick. Had a go of this around croft and i was amazed at how well it stuck to the road and how well it drove.
Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url &amp; =
Posted 28th Mar 2014 at 12:37
daver6
Love this like, but wish it was working and a little cheaper
Wishbone Polybushes available
Posted 28th Mar 2014 at 12:48
Jake
Cheers lads, and the price is supposed to be pounds!
Dave, it's working fine!? Come and buy it Big grin
The 205
205 GTI6 For Sale
Off Racing!
Posted 28th Mar 2014 at 12:55
daver6
What about the belt, speedo and rev counter? :p
Posted 28th Mar 2014 at 13:00
eddy_gti6
Rev counter needs wiring in, new resistors I think as old ones were too big causing the coil packs to burn out.
Speedo is a cable, it snapped at croft. I gave him mine out of the 205 I had but think its different.
Belt as any car needs replacing at some point but dont think jake has any history with it.
All a pretty easy fix really Thumbs up
Posted 28th Mar 2014 at 13:46
jimmyrallye
Cracking little motor any chance it could come with 12 months not if price met
Posted 28th Mar 2014 at 14:42
daver6
So potentially needs the wiring looked at and belt belt before it goes on road again?
Posted 28th Mar 2014 at 14:51
Jake
Wiring is fine, the wiring for the rev counter is four wires that tap into the coil wires, I've just took it off as it was causing a problem, someone sells the kit to get it working properly on the 205 forum with correctly size diodes. Car will run spot on!
I only say the belt needs changed as its a little loose and as eddy says I don't have any history for it, I've done a trackday and a sprint on it and its been fine, I say change it as a precaution but I would happily do another trackday on it.
Ill be putting another 12 months MOT on it when it runs out as most people want to drive it away.
Only reason it hasn't sold yet is because I lost the keys for it a few days after advertising it lol I had a decent amout of interest as I put it on a few forums, new locks came last week and I've just fitted them so ill be putting this on pistonheads soon.
The 205
205 GTI6 For Sale
Off Racing!
Posted 28th Mar 2014 at 16:58
daver6
wiring with regards to the coil packs is what I meant?
Posted 28th Mar 2014 at 18:18
