Author Subject: Rallye aux belt setup
Cjwatson27
Hi I'm after a good rallye aux setup to remove the aircon from my gti6 Smile
Posted 24th Jan 2014 at 18:04
pug_306
Will a 16v XSi non a/c be the same set up ?
1992 205 GTi6
205 Turbo 340bhp
Posted 24th Jan 2014 at 18:16
Cjwatson27
Hmm i don't know hopefully someone will be along soon to answer that LOL
Posted 24th Jan 2014 at 18:24
JWP EFi
Turbo Legend!
Yes
Posted 24th Jan 2014 at 22:40
Make sure you clean out the thread on the mounting bracket as aircon set up uses different bolt holes No
Posted 24th Jan 2014 at 23:07
Also removing the pas pump will make life easier to change the setup just make sure you catch the spacers when you undo the pump bolts
Posted 24th Jan 2014 at 23:08
Cjwatson27
Cheers t99pug , i take it these bolt holes are on the block and are unused until i fit this ? Will the belt be the same has a rallye ? Thanks for the help
Posted 25th Jan 2014 at 07:34
si_batt
Hi there, I'll be breaking an xsi non air con in the next couple of weeks, so if you can wait a short while I may be able to help with this.
Posted 27th Jan 2014 at 19:53
Cjwatson27
The garage have sorted by using a shorter belt
Posted 28th Jan 2014 at 19:54
