Author Subject: Broken KW damping adjuster
Hi guys,
I think I may of asked this before, but I am going to start getting my act together and sort the various issues with the car out.
Now quite a long time ago, I misplaced the plastic knob that adjusts the damping on my KW v2's, and decided that in my time of need that some small pliers would suffice. On the first turn with very little pressure, it snapped off Angry
Its proper small so think I would be unable to get someone to weld it back on, and not enough contact patch to use a metal glue etc, as doubt it would hold.
I believe I have the early type, but do you guys have any suggestions on how to fix? Is there anywhere in the UK I could send the unit off to to have that whole bit replaced?
Any thoughts, ideas welcomed Smile
Thanks
Posted 23rd Jan 2014 at 12:28
Its the middle one in that picture. Not the later types that used an allen key etc.
Posted 23rd Jan 2014 at 12:35
JWP EFi
Turbo Legend!
Although my kw's are not broken, i'm keen to know if anyone in the uk can carry out work on these
Posted 23rd Jan 2014 at 18:18
pugheaven
I know it's a bit of a mission but you could adjust them by turning them by hand (coilovers removed and maybe removing the spring and turning the rod by hand)
Posted 23rd Jan 2014 at 18:35
If you have the later type, then yes.
I just spoke to KW and the type I have were discontinued last year.
Afraid not mate Sad
The adjustment rod goes down to the damping valve at the bottom of the coilover, which is all contained in the main body. So I guess you could do it, but would need to take the main body of the strut apart.
Posted 27th Jan 2014 at 10:32
tvrfan007
When one of my konis broke in a similar manner, there was a fella in spalding that could service suspension. Ill try to find it.
http://www.koni.uk.com/home/index.php?option=com_content&view=article&id=76:damper-workshops&catid=53:dealers&Itemid=126
give him a call I bet he could advise.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 1st Feb 2014 at 22:50
Cheers Si Smile
Just had a look on the link above, and assumed it would be SP suspension. Googled it and one of the top results was a thread on here from you, giving them a thumbs up Laugh
http://www.306gti6.com/forum/showthread.php?id=130157
Posted 3rd Feb 2014 at 10:55
For the record, this is what mine is like...
What it should be..
What mine is now like Sad
Posted 3rd Feb 2014 at 10:58
craig903
Too small to drill a tiny pilot in it? Tap a hole then with a high tensile stud and another bit off rod then screw together? although If it snapped the hole valve may be seazed.
208 GTI Owner
Posted 3rd Feb 2014 at 12:23
Thanks Si, just spoke to Shaun and they can replace the parts and check it all over Smile
Happy days
Posted 3rd Feb 2014 at 16:28
