| Author | Subject: 6 window switch |
nadine
Senior User Location: Dunfermline Registered: 02 Mar 2008 Posts: 525 Status: Offline |
Ok so I have a bit of a strange one. My current 6 window switch is cosmetically damaged and the button for the drivers window doesn't work. The passenger button and electric mirror part all work. I have purchased 3 different window switches now, told they are working but when I fit to my car they don't. Surely I can't be that unlucky to have bought 3 non working switches? Could there be a different issue? Don't want to keep.buying if they are never going to work |
calibra306
Seasoned Pro Location: Gravesend, Kent Registered: 06 Nov 2011 Posts: 1,315 Status: Offline |
There are different switches dependant on year/phase.The connecting plugs also vary. Ie mine is a phase 2 which when you look at the under side of switch it only has 4 pins where the later has more connecting pins ________________________________________ V6 Power!Faster I can go the better! Its not what you drive, its how you drive that wins the race! |
calibra306
I meant different switches as in the internal workings and the connecting plug.cosmetically they all look the same ________________________________________ V6 Power!Faster I can go the better! Its not what you drive, its how you drive that wins the race! |
nadine
Ah ok so for example a phase 3 switch wouldn't work in a phase 2? |
nadine
Oh and I see you make black masks |
Rich E
nadine wrote: Ah ok so for example a phase 3 switch wouldn't work in a phase 2? Correct. There's a mini-FAQ on this: http://www.306gti6.com/forum/showthread.php?id=74364 ________________________________________ Rich |
nadine
Thanks Rich it's driving me mental! |
jimmyhackers
Seasoned Pro Location: birmingham Registered: 14 Jun 2011 Posts: 1,302 Status: Offline |
might be worth spending 20 minutes of your time cleanign the door plug pins on either connector side with a little peice of emery paper.they have a habit of corroding/green gunking up. ________________________________________ the world is changed by people in sheds |
nadine
My drivers loom is currently greened up at the Mo. Would that stop just the drivers window button on that switch stop working? Bare in mind all other parts of that switch work |
scotzman
Seasoned Pro Location: Dundee Registered: 24 Jun 2011 Posts: 1,408 Status: Offline |
Are you sure its not the drivers window motor?________________________________________ '90 1.6 205 GTi, '98 306 GTi-6 |
nadine
I havnt checked the motor, wanted to try switch first as the obe I have no longer clicks. The new switches I have been getting don't work anything, even tho my exisiting switch does everything except drivers window |
