Author Subject: engine swap
Cjwatson27
Im fitting the engine from my gti6 into my xsi . What do I need to do with the imboliser is it just a case of unlocking by unplugging it while it's running , or do I need to swap the keys and ignition barrel over from the gti6 . Plus is there anything else i need from the car . I'm sure this has been covered before i just can't find a solid answer
Thanks for help
Posted 13th Jan 2014 at 17:31
Cjwatson27
I think ive found the answer now , where do i find the transponder , is it near the ignition barrel ?
Posted 13th Jan 2014 at 18:49
p-silva21
Do you know where is the Airbag ECU? The transponder is above it but you need to remove a panel before... you´ll also need gti6 shafts
Posted 13th Jan 2014 at 20:02
p-silva21
oh, and don´t try to start up the engine without removing the transponder as you´ll lock the ECU again.
Posted 13th Jan 2014 at 19:27
Cjwatson27
No not sure where that is , so if i swap the transponder , ecu and the chip out of the key , all should be good ? Yeah ive got the shafts swapping the mechanics over seems straight forward it's the ecu thing I'm worried about
Posted 13th Jan 2014 at 19:29
p-silva21
1- Remove the gearstick and handbrake panel
2 - In front of the gear lever you´ll see a electronic unit with some orange cables..
3- Above it, you have a small compartment that have the transponder.
4- Remove the transponder.
5- Install the unlocked ECU and its done
Posted 13th Jan 2014 at 19:33
Cjwatson27
Ok thanks a lot hopefully the garage should have it up and running tomorrow
Posted 13th Jan 2014 at 19:36
p-silva21
just make sure you don´t start the engine with the transponder connected..I´ve found it in the hardest way...
Posted 13th Jan 2014 at 19:40
si_batt
Why are the gti6 shafts required? I'm doing a similar conversion but sticking with the 5 speed box. Presumably this means I don't need the gti6 drive shafts?
Posted 13th Jan 2014 at 19:42
That's the airbag ecu not ABS,
Abs is under the bonnet behind nearside headlight. But yes you need the little transponder chip from inside the key to the gti-6, the pickup ring from around the ignition barrel, the engine ecu and the immobiliser ecu from in front of the gear stick above airbag ecu. Thumbs up
Posted 13th Jan 2014 at 19:47
Cjwatson27
Yeah I think the shafts are needed to use the 6 speed gear box
Posted 13th Jan 2014 at 19:48
p-silva21
off course its the airbag ecu lol sorry my bad Smile
This image is not mine but it will tell you why
if you use the XSI ones you´ll have gearbox oil spread all around..
Posted 13th Jan 2014 at 20:06
Cjwatson27
Right got it cheers guys Thumbs up
Posted 13th Jan 2014 at 20:10
p-silva21
si_batt as you can see, the shaft in right side is the xsi´s one and if you use it, the shaft won´t "connect" with the gearbox bearing to avoid oil leak. the left side shows the gti6´s one that is shorter and will fit straight in Thumbs up
Posted 13th Jan 2014 at 20:11
Cjwatson27
Ive got a phase 1 ecu which came with the cams i brough from rich6 will that just plug into my phase 2 wiring and work or is it going to start complicating things and best off forgot ?
Posted 13th Jan 2014 at 20:41
p-silva21
Do you know the cam specs and if that ecu have been remaped for those cams?
Posted 13th Jan 2014 at 23:46
Cjwatson27
Nope they were the unknown cams of rich6 i think the ecu just has a higher rev limit , I'm going with the ecu from the gti6 , I'll try the ph1 if it works all good if not ill eBay it
Posted 14th Jan 2014 at 19:40
