displaying posts 1 to 2 of 2
Author Subject: Lynx SC kit question
gman
Evening all,
I'm not completely daft, but certainly not in the know when it comes to engines. However, can someone explain to me why the LB supercharged kit doesn't have a blow off valve?
If my logic is correct, the charger will continue to produce pressure even when off throttle as it's crank driven. So what happens to the boost? Surely this will create a back pressure on the charger and potentially damaging it?
If I were to run aftermarket management, would the kit stay the same (i.e. throttle body before the charger) but allow a dump valve?
Many thanks
Graham
1992 Onyx Black 205 GTI-6
2005 Honda S2000 (Sold)
2002 Audi S3 (Sold)
2005 Clio 182 Trophy (sold)
Posted 12th Jan 2014 at 23:13
Because the charger is after the throttle butterfly it is merely spinning in a vacuum attempting to draw air in therefore no boost is made. Until the throttle is opened and it has air to compress and make into boost. If the charger was before the butterfly it would make boost all the time and need to dump it.
Posted 12th Jan 2014 at 23:19
