Author Subject: Seatbelt removal & fitting
rhyds
I have just bought a 306 rallye that was a bit of a track ish day / autotest car.
It hasnt got any seatbelts front or rear
I intend to take the belts from my donor gti6 & fit them to the rallye
And advice on how to do it without a lot of dammage or hassle?
Or even better is there a step by step guide about?
Posted 9th Jan 2014 at 23:00
Underground375
Not as hard as you think, just remember tho the seat belt holders are angle sensitive, so you will find you cant pull the belt out unless it bolted to the car.
Posted 9th Jan 2014 at 23:03
Is your donor 6 a car you care about trying to sell the rear quarter trims and ABC pillars? If not it's easy and the careful approach doesn't matter to get to the belt bolts.
Rears remove C pillars from body Torx screws to expose 17mm holding bolt (iirc if not 19mm) unbolt from chassis then move rear seat up and undue the bolts holding them to the chassis. Centre belt is obviously all bolted under the seat.
Front belts need the rear quarter cards removing, screws top and bottom in line with B pillar as well as the other hidden and obvious screws around card and behind pocket panel etc. Pull the seat belt adjustor cover off to reveal screw holding that to the B pillar that then exposes the bolt to release the top of the belt. Then undue the bolts holding the belt to the metal rod going into the frame of the car in the foot well. Wiggle these around to release from being attached to the car and remove the main unit from the car. Be careful though as there are quite a lot of different seat belts that were fitted through the years so may not work swapping from donor to rallye due to angle of body and ball bearing in the unit that gives the release and lock function. More than likely will work though.
Once you start removing the plastics it all becomes fairly easy.
Posted 10th Jan 2014 at 00:40
rhyds
thanks for that. slight change of plan as i have got some in my donnor rallye shell so im assuming rallye to rallye should be ok. hopefully give it a bash tonight!!
Posted 13th Jan 2014 at 11:44
rhyds
right, i have managet to most of the bits out of the rallye (stage 1 of fitting) but in the process have broken the bit that slides up & down on the pillar that the belt goes through
any tips on the best way to remove these properly?
Posted 28th Jan 2014 at 17:59
russbez
what ever you do dont open them LOL
i made the mistake of thinking one of mine was broken, took a peek inside and near took my face off
My Rallye project thread
Posted 28th Jan 2014 at 18:22
rhyds
Open the seat belt reel you mean ?
Posted 28th Jan 2014 at 19:36
How you manage that? Glaringly obvious once you pull the adjustor cover off.
Posted 28th Jan 2014 at 20:31
rhyds
managed it through a lack of knowledge!!
Posted 29th Jan 2014 at 09:16
