Author Subject: dash back lights
rec bri
Need some fresh ideas, I have lost the lights to my clocks, they still move but aren't illuminated, ( stop, mileage, headlight, and main beam work ) just background lights not working
I've changed fuses and changed bulbs, but still don't work any ideas ?
Posted 9th Jan 2014 at 16:04
is your dash illumination adjuster plugged in?!
Posted 9th Jan 2014 at 16:09
rec bri
Don't have one just height adjustment
Posted 9th Jan 2014 at 16:11
cully
even if you have no ill adjuster remove the panel as there will be a link instead of the adjuster,if the link unplugs you get no dash lights Wink
Posted 9th Jan 2014 at 16:30
rec bri
Your right unplugged it refitted, but no lights I'll dig out a multi read in a bit to check it
Posted 9th Jan 2014 at 16:47
rec bri
All looks ok with that switch ( was in fear of a broken wire)
I blindly changed the fuses for the instruments from the FAQ
Unless I go though them all ?
Posted 9th Jan 2014 at 17:00
cully
fuse 19
Posted 9th Jan 2014 at 17:21
rec bri
cully wrote:
fuse 19
Yep that was it, but some bulbs didn't light so I may give them a wee twist round but its looking good so far thank you very much
Posted 9th Jan 2014 at 18:18
