Author Subject: Spoox BTCC Inlet
eddy_gti6
Anyone know anything about this and what else would be needed? £300 doesnt seem too bad
spoox BTCC Inlet
Posted 9th Jan 2014 at 15:03
miles
That was on Touring car spares along time ago
www.pugracing.com
Posted 8th Jan 2014 at 23:00
eddy_gti6
Know anything about it and what else would be needed? Where would the throttle body be located?
Posted 8th Jan 2014 at 23:07
JWP EFi
Turbo Legend!
Have a look at the VLR stuff
Posted 8th Jan 2014 at 23:21
eddy_gti6
Any links?
Posted 8th Jan 2014 at 23:56
eddy_gti6
Take it this would need an air box made up to allow to run a single throttle body. Would it pretty much be as good as running a set of jenveys if set up right?
Posted 9th Jan 2014 at 15:06
staley_306
You need the carbon airbox along with the throttle body. Also this uses 8 injectors. It would be much quieter than itbs
Posted 10th Jan 2014 at 07:56
eddy_gti6
The 8 injectors is optional I imagine, would run fine with 4
Posted 10th Jan 2014 at 08:19
eddy_gti6
I will get more pics of this tomorrow. Could do with fi ding out dimensions of the carbon plenum so I can have one made up. Also found out these ran the 70mm single jenvey throttle body too.
Posted 13th Jan 2014 at 11:22
"Product no longer available"
Have you bought it?
Posted 13th Jan 2014 at 11:37
eddy_gti6
Maybe I have yes haha. Nice discount to go with it
Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url &amp; =
Posted 13th Jan 2014 at 11:41
eddy_gti6
Here is the spoox inlet I have bought. Has the option to run 4 or 8 injectors, has 90mm long carbon trumpets, thenk they maybe 45s but will f8nd out tomorrow when it arrived
need to have a shell made up like the one below and they also run a 70mm jenvey single throttle body
Posted 13th Jan 2014 at 13:33
rallyeash
Be interesting to see how it works but my thoughts are it's a compromise of a full itb setup
309 3dr K20 Type R
Posted 13th Jan 2014 at 13:42
eddy_gti6
Cant see this being to bad to be honest if it was good enough to run on a btcc car. May try running standard throttle body in this to get it running see what happens till I get hold of an omex or something
Posted 13th Jan 2014 at 14:42
rallyeash
Yes but the BTCC cars had to run a single throttle because of regs.
309 3dr K20 Type R
Posted 13th Jan 2014 at 14:52
eddy_gti6
Just fancied something different to everyone else. The touring cars still made good power from these so cant see it being bad.
Posted 13th Jan 2014 at 15:30
ryangti6
That's different to the touring car ones I've seen, they usually still look like a standard manifold with plenum etc and ran a odd shape carbon airbox where the oe ones fit but a lot larger. As far as I know all they did was cut them open, remove the trumpets and open the runners then weld it back up.
I've never seen another one of those so it'll be interesting to see how it goes.
Ryan
Posted 13th Jan 2014 at 16:56
eddy_gti6
They were used on the 406s mainley with the 2.0 XU engines. Seen 1 other 306 running this but with an alloy plenum. I have a pic somewhere, I will hunt it out
Posted 13th Jan 2014 at 18:03
eddy_gti6
This would be ideal for what i need but FU*K me! £629+vat Laugh my ass off
REVERIE
Posted 13th Jan 2014 at 21:51
pugheaven
Try pug performance, Colin had a few that he got from longmans when they shut down
Posted 13th Jan 2014 at 22:49
pugheaven
eddy_gti6
I will look into in. May give them a call tomorrow to see what they have. Wouldnt mind a btcc air box and header tank to be honest
Posted 13th Jan 2014 at 22:53
eddy_gti6
Manifold arrived today. Also found a plenum for it as well what should be here by the end of the week Cool
plenum I have found for the time being
Posted 14th Jan 2014 at 20:05
Cjwatson27
Are you still going to try the standard throttle body with it ?
Posted 14th Jan 2014 at 20:12
eddy_gti6
Yes will give it a try. If not al buy a jenvey 70mm single throttle body then I will have too keep my eye out for a new ecu.
Posted 14th Jan 2014 at 20:43
