displaying posts 1 to 25 of 48
Author Subject: Cully's Bianca 6
cully
ive been here a while now not posted much
but I think its about time i shared my weekender toy
it has been through this forum before a while ago
i bought it about 10 months ago saving it from a sad life
in that time i have spent money and a lot of time gettiing it back to a respectable car
list of things i have done include
rear beam
rear mounts
rear brakes
cleaned painted rear archs
fitted font and rear arch liners
new clutch
cambelt kit and w/pump
cleared painted front archs
new rad
painted cleaned front crossmember
Pas relocation
removed aircon pump/condenser
replace front wishbones complete
new front brake hoses
refurb front brakes
weld repair top engine mount
converted IR central locking to RF for better range
the list goes on
heres some pictures for you to pick at
enjoy
Posted 4th Jan 2014 at 14:12
mik
Looks good.
Cherry Rallye SOLD
Posted 4th Jan 2014 at 14:21
RetroPug
Seen this on the other forum, lovely looking car!
What exhaust are you running?
Posted 4th Jan 2014 at 14:34
cully
thanks for the comments guys
the exhust was already on the car when i bought it
i believe from info in the document folder its a stainless single box longlife system its rather loud!
god know's how it passed coombe's noise test at 88db @ 4k when i measured it beforehand it was 98db @ 4k
pss there is a lot of info what i have done on the other forum
Posted 4th Jan 2014 at 14:44
Welcome along matey Wave
Car looks stunning Love
Posted 7th Jan 2014 at 13:46
superchargedblack1997gti6
Looks great mate, may have to try white wheels on my rallye looks really nice!
Posted 7th Jan 2014 at 14:35
cully
white white and more white its a b**ch to keep clean Smile
but to drive it makes up for the effort Wink
thanks guys
Posted 7th Jan 2014 at 18:54
mcvite
Nice looking gti-6 you have there mate Thumbs up
http://s1160.photobucket.com/albums/q486/mcvite/
Posted 8th Jan 2014 at 05:22
cully
Off to germany and the Nurburgring in 16 days so thought id best put another picture up
Big grin
cully has attached the following image:
Posted 13th Apr 2014 at 18:48
eddy_gti6
Quite fancy doing the ring In july. Cars looking good Thumbs up
Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url &amp; =
Posted 13th Apr 2014 at 19:07
cully
as im sat at home dodging the showers i thought id share with you all what has happened with my car since buying it
i think its basicly a list of what everyone has done just to keep these little gems on the road
bought the car in april 2013 with a weeks MOT left i picked the car up knowing of quite a few faults
but i liked the colour and it was local to me
to get it through the first MOT was quite an ordeal, as i got rolled by the MOT tester, having a late friday MOT once he had a list of fails he didn't complete the MOT negleting to test the front half of the car!
this was going to be my list of todos but ended up being a lot more
so here goes
for first MOT.
Front brake line flexys
front ball joint X2
steering rack gator
Handbrake cable
O/s Front wheel bearing
New Re-con rear beam
front Wishbones X2
I also done
Cam belt +water pump + idlers
New clutch
new s/h Radiator + bottom hose
so once it was home it was time to enjoy it a little my first outing was Pugfest 2013 the car was loud due to the DeCat and single box system made my ears ring on the trip up the M5
car started to get a whine to it so ended up fitting
a New aux idler pulley that sorted this.
i bought some gear linkages at pugfest so on retuning i serviced fixed and fitted a few bits i had around
Comp gear linkages
Oil+ Filter change
fitted strut brace from HDI
changed the rear lights to std
fixed the Tailgate central locking
fixed the N/s central locking
re fixed door trims re-glued fabric trims
removed cleaned painted inlet manifold plugged resonator
reverted back to STD air filter
A/C fan switch mod
repair battery terminals
replaced rear beam mounts (rubber type)
after the summer show season was over i decided to sorn the car so i could do a little preventative maintenance which took till after Christmas when i bought tax again on 1st Jan
renew replace broken arch liners
clean off paint under arches x4
clean off paint front lower cross member
clean off paint front upper cross member
removed black masked fronts returned to std
Posted 11th Aug 2014 at 15:58
cully
to continue
once it was back on the road a few things started to show so set to on these
fitted new front fogs
repaired alarm
retro fitted RF central locking integrated into existing alarm
cleaned up freed serviced 4 x brakes
time came for some weld repairs!
weld repair cracked engine cradle
weld chock top engine mount
weld repair rebuild drivers seat
replace Radiator for new alloy type
remove air-con pump + pipework
relocate PAS pump into A/c position re-pipe PAS returns
weld repair chassis box to outer cill under car
replace rear engine mount for vibratec
replace gearbox drive-shaft oil seals x2
with the removed rubber beam mounts i made some solids so fitted these
replace rear shocks for B4's
replaced exhaust back to STD including CAT + BB
replace drivers window plastic clip
replace front hubs for 18mm + wheel bearings + BJ's
replace track control arm
replaced P-bushes for Partner type
2014 FCS showed i needed some oil cooling as i was seeing some high temps so went and fitted a 16 row cooler with thermo take off plate i managed to fit this between the std rad and fans where the A/C rad should be
have also through the year
replace O/S rear stub shaft as it was bent
replaced the front hubs and bearings from 16mm to 18mm
the car went to germany at the end of April and i took it round nurburgring which i really enjoyed
I will be doing it again next year
on returning the car was up for MOT To which it was driven in and Passed with no Adviserys
and to celabrate i gave her a service of
oil and filters
Posted 11th Aug 2014 at 15:56
cully
Oh! and the car thinks this place is home!
Posted 11th Aug 2014 at 16:06
barrym
Hi mate, I didn't realise just how much time and effort you have put into the car. Fantastic effort and looks stunning.
Great thread, especially as you seem to have done a lot of the work I plan to do on mine.
Black Rallye occassional toy
Posted 11th Aug 2014 at 19:42
cully
yes Barry like I think most people who own and keep these cars have the same problems to overcome
Posted 11th Aug 2014 at 20:00
mik
Great work, I enjoyed reading your thread. Nice car too.
Cherry Rallye SOLD
Posted 11th Aug 2014 at 20:20
p-silva21
Nice project Smile Good to see how much you take care of your car too..
Posted 11th Aug 2014 at 20:28
cully
time for some new pictures I believe after another year of ownership
just brought this back from MOT, 13months MOT and no advisor's Smile yah!
the time Ive put in when I bought the car is beginning to pay with more time driving it now,
recently fitted an enlarged throttle body which has made quite a difference to the eagerness of the car
cheap mod too as i did it myself
Posted 20th Apr 2015 at 11:32
99rallye
The white on white looks great!
Posted 20th Apr 2015 at 15:39
Chr1sch
Looks great - what car is the throttle body from?
Posted 20th Apr 2015 at 16:55
Beautiful car & amazing work Thumbs up ...
Posted 20th Apr 2015 at 17:36
RetroPug
It's a gti6 one that has had material removed.
Posted 20th Apr 2015 at 17:49
Puggitt
Did you post about that tb on the 6 Facebook page?
Posted 20th Apr 2015 at 21:20
cully
yes there is a few more photos of it there too
Posted 21st Apr 2015 at 00:45
cully
well car is nolonger Knocking its tits off
ive removed her heart today!
time to treat some rust in the bay nothing serious then refit a rebuilt engine Smile
Posted 9th Aug 2015 at 20:48
