Author Subject: Possible driveshafts issue
superchargedblack1997gti6
Morning another issue I have with the car since I bought it is very jerky when coasting. does this sound like a driveshaft issue? if it is I'm lip cult enough to have a pair of brand new shafts sat in the garage just wondering if people think it's this before I change them over. cheersThumbs up
Posted 28th Dec 2013 at 09:28
devere
More likely engine mounts with excess movement maybe? Wouldn't imagine shafts cause a jerky-ness.
Posted 28th Dec 2013 at 09:29
Shafts gone will cause gearstick shake, not jerkyness.
As Devere says, either engine mounts or a misfire on coasting causing excess engine movement.
Posted 28th Dec 2013 at 09:58
the gear stick does shake. it's at low coasting revs say around 1.5-2.5k under load there's no jerkiness and at high revs none. still sound like mounts?
Posted 28th Dec 2013 at 10:39
Under load is where you would find gearstick shake if the shafts had gone. Yes
Posted 28th Dec 2013 at 10:44
Well I have a full set of vibratechnics mounts I may try swapping them over see if that helps. just I was told that they'd been changed before I got the car. but maybe they have already failed Thumbs down
Posted 28th Dec 2013 at 11:10
devere
Top mount broken where it bolts to the body, as per the seemingly common failure?
Posted 28th Dec 2013 at 11:58
Could be, but that is usually accompanied by a 'click' sound when going on and off the throttle.
Posted 28th Dec 2013 at 13:27
What would cause a misfire that you talked of stan because I may as well preempt and repair whatever that would be too! many thanks guys
Posted 28th Dec 2013 at 14:33
pugheaven
The gearbox and top engine mounts were changed when I had it, not new items but ones from the grey car!
I did have a look for cracks in the mount but it didn't appear to have any when I changed them bud
Posted 28th Dec 2013 at 14:45
No probs mate just seems everything seems to fck up in one go Poxy French cars LOL
Posted 28th Dec 2013 at 15:19
pugheaven
I know how you feel mate, keep thinking about selling the dimma once it's done, fed up with working on cars all the bloody time Sad
Posted 28th Dec 2013 at 15:30
I meant a misfire whilst the engine was off gas, probably rather unlikely but just looking at all avenues.
Posted 28th Dec 2013 at 16:38
devere
Is it actually a misfire or is it just a bit of popping on the over run? What exhaust has it got? Or is the whole thing relatively standard?
Posted 28th Dec 2013 at 17:17
it's highboost supercharged pops and bangs like hell
Posted 28th Dec 2013 at 17:20
