Author Subject: Really stupid question
markylee
Sorry for this really stupid question, but how do you make sure you've got the clutch fork behind the bearing when refitting the gearbox. Is it just a case of feeling behind with your fingers. I feel a bit stupid at the moment
Posted 27th Dec 2013 at 10:54
footah212
There is an inspection panel on the bell housing which you can just see into I think.
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 27th Dec 2013 at 11:08
If you shine a torch down the gap at the top, through the cutout next to the crank sensor, you will just about see it. Yes
Also, once the box is on and flush with the block, temporarily fit the clutch release arm. Does the pin hole line up so that the arm sits in the same place as before you dismantled it? If so, I'd say it's pretty much sure that you done it right. Once the arm is on and the fork IS located correctly, you will find that there will be a small amount of backwards and forwards free play on the arm. If it's stuck solid, then something is wrong.
Posted 27th Dec 2013 at 11:25
markylee
Cheers, just a bit of fiddling then. Just wanted to make sure I wasn't missing something
Posted 27th Dec 2013 at 11:45
