displaying posts 1 to 25 of 30
Author Subject: Pull back help please
Pug bazza
Help guys, I just come back from Bedford and on the way back, when the car was at low speeds like 45-50 I felt a little pull back the gear I was in was 5th but 60 and over it felt fine can anyone tell me what this is, I thought it was just wind but it ain't that windy outside thanks guys
Posted 26th Dec 2013 at 16:39
RetroPug
Were you completely off the throttle?
If the car doesn't like rolling in gear or picking up the revs from rolling in gear it could be the ICV or throttle position sensor.
Posted 26th Dec 2013 at 16:45
Pug bazza
It's when I come of throttle so, like I'm doing 60 I let go of throttle and let it go down to 45-50 and keep it there, that when it does it
Posted 26th Dec 2013 at 18:51
RetroPug
Is your ICV clean? If you have a multimeter you could try testing it as well?
Does it do this in other gears?
Posted 26th Dec 2013 at 18:53
Pug bazza
No I only realised in 5th gear, how would I test it and if I was to clean it what would be the best thing to use for cleaning it thanks
Posted 26th Dec 2013 at 20:29
RetroPug
http://www.306gti6.com/forum/showthread.php?id=17020
Here's the FAQ on it.
I've cleaned these a few times, I always remove it from the housing thing it sits in, and remove the two o-rings. I use brake cleaner to clean the housing and the valve, put a tiny bit of WD40 on the valve after cleaning, and wipe the o-rings with WD40.
I also remove the whole inlet pipe and clean that as it gets full of muck and oil from the breather on the throttle body.
It might not be the ICV but if it hasn't been cleaned and it is full of muck it is worth doing anyway as it is a very quick and easy job.
Posted 26th Dec 2013 at 21:06
Pug bazza
Thanks retro pug, il have a go at it hope it goes well il let you know how I get on thanks again
Posted 26th Dec 2013 at 23:45
Pug bazza
Sorry to be a pain, would I have to reset the ECU once I done it as I read on the FAQ and it mentions resetting, and if so how do I reset thanks guys
Posted 26th Dec 2013 at 23:49
RetroPug
Not sure, but give it a go just to be on the safe side.
Here is the ECU reset FAQ:
http://www.306gti6.com/forum/showthread.php?id=16861
Basically, if you've disconnected the battery to clean out the ICV etc. then if you refit it afterwards it should be fine, if cleaning it doesn't work, the ICV itself could be going dodgy or it could potentially be something else.
Posted 27th Dec 2013 at 01:00
Pug bazza
Ok thanks il try that
Posted 27th Dec 2013 at 08:52
It won't be the ICV when the engine is above idle already. No
What rpm was the engine doing at 45-50mph in 5th at the time?
Posted 27th Dec 2013 at 09:43
RetroPug
It sounded like the problem was when the engine was allowed to have the revs drop to barely above rolling in gear? The icv has caused problems with this for me in the past.
Posted 27th Dec 2013 at 10:40
Pug bazza
The revs are 2500 when this happens
Posted 27th Dec 2013 at 22:08
Pug bazza
I just seen some videos on peugeot 306 icv problems on YouTube, and mine ain't that bad because the ones I seen are Idling quite badly, with mine when I start it from cold it revs stay abit above 1000, but as it warms up they drop to just under 1000, this pull back problem only occurred as I was doing 60
And dropped speed down to 45-50 but once increased up again it felt ok, so would you guys think it's the icv ? Hope you lot can help
Posted 27th Dec 2013 at 22:59
Lambda sensor starting to play up.
If this starts to happen constantly, unplug the lambda sensor and then go for a drive. If the problem has gone, then replace the lambda. Yes
Posted 28th Dec 2013 at 08:22
Pug bazza
Thanks stan, sorted so if it's not the lambda sensor it will be the icv, I have noticed abit of ticking/knocking where the lamba sensor goes in to the manifold would this be a sign of it on way out or is that just me thanks guys
Posted 28th Dec 2013 at 09:15
Lambda going into the manifold? Are we talking about a GTi-6 engine here, because I was under the impression it was?
If not, it sounds like you have a 'TU' engine there. However, the same diagnosis applies. Unplug the lambda to see if that causes the issue if it happens again. The sensor itself will fail internally it if fails, so the "ticking" noise you hear won't be anything to do with it. Wink
Posted 28th Dec 2013 at 09:55
RetroPug
Hmm it could also be the MAP sensor as this can cause hesitation but I'd have thought that that would be in every gear.
On a gti-6 engine these plug into the top of the manifold and are also pretty cheap.
If you do have a gti-6, the lambda sensor will be in the exhaust at the catalyst.
Does this problem only occur when the car is warm? Have you noticed a drop in fuel economy?
The ICV can cause problems without making the idle seem too bad but it doesn't sound like it is the ICV in your case, however, it is still well worth gently giving this a clean if you've never done it.
Posted 28th Dec 2013 at 10:14
Pug bazza
Mine is a TU engine sorry should have mentioned it and it only done it the once when I drove it the other day I haven't driven it since but is it a mostly likely a lamba sensor, and does the MAP sensor apply to the TU engine , fuel economy seems normal to me, but I only drive it 1/2 times a week but warm it all up before driving it thanks guys sorry about not mentioning TU engine
Posted 28th Dec 2013 at 10:29
You need to drive it again really to see if the symptom still remains. If it does, then I'm voting lambda as first port of call. Smile
Posted 28th Dec 2013 at 10:48
Niall
The lambda should never go into the manifold unless its after the collector otherwise it won't do its job properly.
Posted 28th Dec 2013 at 11:00
Pug bazza
Where would I find the lamba sensor on a TU engine ?
Posted 28th Dec 2013 at 11:05
Niall
In the down pipe from the manifold. Depending on the age, you might have a pre and post cat lambda.
Posted 28th Dec 2013 at 11:08
Pug bazza
OK il have a look so you guys think it's more likely to be a lamba sensor, also to make it easier for me, is it the blue connector one or green connector one sorry to be a pain thanks
Posted 28th Dec 2013 at 11:30
RetroPug
I don't know which connector it is but the lambda is a probe that plugs into the exhaust.
It's easy and free to test so probably a good thing to try first!
Posted 28th Dec 2013 at 12:09
