Author Subject: Cig lighter query.
bennn
Is there a way to make the cig lighter stop working when the ignition is off? Like is there a fuse I can pull out or something? I try to remember to unplug my heated seat cover but every now and then I forget and end up with this.
Thanks and merry Xmas
Cherry Red 306 HDI
Posted 24th Dec 2013 at 11:02
rallyestyle
Oh dear Doh
It would be a real faff trying to play around with the fuses. Id be tempted to run a feed from the light in the cubby hole thingy below, pretty sure this goes off with the ignition Yes
Just Drive It
Posted 24th Dec 2013 at 11:23
Move fuse 23 down should do it.
Posted 24th Dec 2013 at 11:26
rallyestyle
Really that simple? Unsure What does 23 control?
Just Drive It
Posted 24th Dec 2013 at 11:28
bennn
Thought there was something like that you could do but couldn't remember what! Cheers TP my warm arse will be eternally grateful once the facking thing starts
Cherry Red 306 HDI
Posted 24th Dec 2013 at 11:30
devere
Buy some wooly pants instead?
Posted 24th Dec 2013 at 13:46
The shunt fuse as Jon says can be put in two positions. The lower position means the cig lighter only works with the ignition, the upper position leaves the power on all the time. Yes
Posted 24th Dec 2013 at 12:20
Moved to Electrical. Smile
Posted 24th Dec 2013 at 12:21
bennn
Jon was right but the lower position means it's on all the time. I've moved it up in line with the other fuses and now it works with the ignition only.
Cherry Red 306 HDI
Posted 24th Dec 2013 at 15:28
Doh
We got it the wrong way round then...at least it was a simple fix. Thumbs up
Posted 24th Dec 2013 at 16:23
