Author Subject: Instruments earth?
jont-
Have an interesting intermittent electrical glitch. From time to time (could be every few minutes, could be I drive the car without it happening), the instruments glitch. Speedo, tacho appear to reset themselves (judder to 0, then bounce to ~110mph/6250rpm), fuel and oil temp go to max, and the odomoeter/trip go to all segments lit. Temperature gauge, headlights on warning appear unaffected. After a second or two showing those values, it will go back to behaving normally. Backlights (cluster lighting) don't dim either.
I've had the fuses out and given things a good dose of contact cleaner, so I'm guessing the next likely candidate is an earth - anyone know where they are and whether there's one common earth that would show those symptoms. Or could it be a slightly dodgy 12v feed?
Doesn't seem to be related to bumps in the road or any other common factor I can identify.
Engine runs fine throughout, so I'm treating it as an annoyance, but would be nice to sort it.
thanks,
Jon
Posted 23rd Dec 2013 at 10:55
superchargedblack1997gti6
I did have a similar problem caused by a water leak meaning hat the instrument panel was earthing itself? any sign of water leaking behind the instrument panel?
Posted 23rd Dec 2013 at 11:05
jont-
Hmmm, guess it's possible. I'll have to pull the thing out Sad
Posted 23rd Dec 2013 at 11:36
One of the main earths inside the car is behind the carpet in the driver's footwell.
Give it a clean/tighten and see how you get on from there. Smile
Posted 23rd Dec 2013 at 11:46
jont-
Thanks stan. Hope it's that, but I'm waiting for the rain to stop before I can have a poke!
Posted 23rd Dec 2013 at 14:18
jont-
Hmmm, been out again in the dry today and not so much as a flicker, so it looks like it might be a water leak behind the panel. Ho hum.
Posted 24th Dec 2013 at 15:49
check your aerial base first mate as if that leaks it'll just wick straight down into the dash! this is one leak I have stopped in my car! tomorrow's job is to silicone the crap out of anything that could be a hole.
Posted 24th Dec 2013 at 16:17
This is a very good shout. Yes
Posted 24th Dec 2013 at 16:22
jont-
Interesting. Could also tie in with the radio reception not being amazing (ie corroded wiring if there's a water leak). Will have a poke later in the hols Thumbs up
Posted 24th Dec 2013 at 18:18
