Author Subject: C38 Belts
Hawkesfire
Hi
I am just building my GTI6 SHB motor and have upgraded to a C38 charger which i have a fitting kit that includes a 8 rib pulley set, i have just tried my dry sump belt on and it catching the bottom pulley as its wider than the 6 rib so my question is could i run a C38 on a 6 rib belt as its only for short races and can be changed at the first sign of any wear?
Dunno
Marty
206 Rallycross GTI6 SC SHB 425 BHP clutch eater !!!
Posted 19th Dec 2013 at 12:59
superchargedblack1997gti6
Marty it will slip the reason for the 8 rib belt is the 6 belt would slip under the loads applied I'm sure that Rich di have a prototype 6 rib belt kit? maybe he still has this? If you ask Rich W I'm sure he can explain? maybe you could modify the dry sump pulley and space it out more?
Posted 19th Dec 2013 at 13:25
Yes, you can use a 6-rib belt but as stated it may slip under extreme load. This was the main reason for upgrading all the aux components to accept 8-rib and make the most of the C38 charger. Smile
Posted 19th Dec 2013 at 17:28
Hawkesfire
Hi
Thanks for the info but i have managed to set the dry sump systems up with the 8 rib belt.
Marty
Posted 20th Dec 2013 at 15:59
That looks awesome mate! Cool
Posted 20th Dec 2013 at 16:01
Hawkesfire
Hi
Thanks for the comment although it should be as i have around £4k in it now just want to see it hit the 451 bhp with loads of torque to see if it will spin the Avon slicks...
just need to work out the 8 rib alternator pulley not lining up and source a belt for it
Marty
Posted 20th Dec 2013 at 16:05
rallyestyle
Nice Thumbs up If only it was going in a 306 Whistle
Just Drive It
Posted 20th Dec 2013 at 16:13
Nice any more detailed pics before you put it in Marty? I'll be putting this on mine now I can see it works!
Posted 20th Dec 2013 at 16:42
Hawkesfire
Hi
Pm me your e mail address and I will send you some hi res pics tomorrow
Marty
Posted 20th Dec 2013 at 17:24
rallyeash
Where did you source your dry sump belt? What make is it too?
309 3dr K20 Type R
Posted 20th Dec 2013 at 20:33
Hawkesfire
Hi dry sump belt came with the dry sump kit from Pace and i got them to throw in a spare as well but on the belt its marked up as Optibelt ZR 210 L
Hope that helps
Marty
Posted 23rd Dec 2013 at 12:24
rallyeash
Same as mine then.
I had a new Goodyear one to fit when I installed my system. Perfect tension with no need for shimming the pump. I stuck the car into a gravel trap and literally stones were everywhere including one into the sump belt which has a nice guard. This caused a small rip in the belt. Still worked and drove pulleys just obviously not safe to use.
I then went back to my local supplier and ordered 2 belts (same place I got my Goodyear one from) they ordered a couple in and next day picked them up and got them for a tenner. They wernt goodyear ones though and I fitted one and it's slacker than the Goodyear and isn't safe to use. The supplier didn't really see my point as normally you'd obviously tweak the tensioner/idler but I tried to explain that I'd have to shim the pump away which isn't something I want to do if I can help it.
So I'm going to order another one online and hope its a touch shorter.
309 3dr K20 Type R
Posted 23rd Dec 2013 at 20:36
