Author Subject: Throttle bodies making a pop noise after excellorator
Demograffix.com
Need advice, I noticed yesterday a small pop noise after taking foot off the excellorator, the car is driving fine, just wondering if It could be a sticky throttle body or a maintenance issue? Any ideas or suggestions welcome, has anyone experienced the same issue.
stevenage black gti 6, 198bhp
Posted 15th Dec 2013 at 09:37
gti6girl
Posted 15th Dec 2013 at 10:12
Demograffix.com
this is the same sound
Posted 15th Dec 2013 at 12:36
Demograffix.com
Anyone know what could be causing this
Posted 15th Dec 2013 at 13:37
gti6girl
If I remember correctly the throttle pot (tp1) had packed up
These and very temperamental and I have change mine twice and my buddies once
It would need to go back on the computer to set it up properly
Posted 15th Dec 2013 at 14:24
Demograffix.com
Cheers this a great help, I will look into getting it sorted. Will it damage the car if I continue to drive the car as it is in the mean time?
Posted 15th Dec 2013 at 16:49
gti6girl
Well it's fuelling will be out. My mate drove every day for about 1yr like this before I changed it. I got it running but was still over fuelling. Needs to be set properly
Posted 15th Dec 2013 at 16:57
raunchz
I'd also check the balance of the throttle bodies
Posted 15th Dec 2013 at 18:05
Mine played up like that when the air temp sensor failed.
Posted 19th Dec 2013 at 19:43
spiky
possible becuase it's running around 21afr or more
MY YouTube Videos'
268+BHP and 860kg = FUN
Posted 20th Dec 2013 at 11:45
rallyeash
bad map, dodgy air flow sensor, dodgy TPS.
its a fuelling issue caused by one of the above. I'd start with changing the Air flow sensor
309 3dr K20 Type R
Posted 20th Dec 2013 at 12:04
