Author Subject: Electric window not working
Cjwatson27
Having issues with my passenger electric windows , I think it might be the door to body loom . What the best way to go about repairing this , I made matters a lot worst last time i messed with one on my ph1 . Any help appreciated Smile
Posted 27th Nov 2013 at 21:57
just pull as much of the loom out as you can and solder it up, trying your best not to put the solder all near each other if possible so it's thinner overall rather than thick in one place
failing that it's a new / used loom. never really had a problem repairing the loom myself
Posted 28th Nov 2013 at 15:55
anth
They often break there, you can try and work out if its that buy holding the button down on the window and moving the loom around as much as possible to see if it will make a contact.
As it could be the door loom itself which are very cheap to buy second hand.
Posted 28th Nov 2013 at 18:03
pete-gti
Might be the switch mine played up, replaced switch and was good as gold
Posted 28th Nov 2013 at 18:07
Cjwatson27
Hmm both the door straps were broken when I got it so I'm thinking its the loom , it doesn't operate from either side when it's playing up could that be the switch , saying that neither speakers working in the front so that probaly confirms the loom . Cheers for the replies
Posted 28th Nov 2013 at 18:13
I'm almost 100% it'll be the loom.
Posted 28th Nov 2013 at 22:39
rich306
Same as above ^ I've repaired many a loom soldering it.
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 29th Nov 2013 at 07:44
