Author Subject: td pro race 1.2 offset query.
Phil white
Picked a set up mega cheap, 16x7 they came off a saxo and I'm told are direct fit. On looking at et stamp it says 6??? Is this right or do I need spacers?
Posted 27th Nov 2013 at 18:06
jorg
you need to look around the outside of the rim like so
306 2.1 S16 Tarmac Rally Car
Posted 27th Nov 2013 at 18:12
Phil white
Top man. Cheers, anyidea what et direct fir should be?
Posted 27th Nov 2013 at 18:15
jorg
e15 and e18 are considered to be direct fit. anything more normally involves using spacers depending on your setup.
Posted 27th Nov 2013 at 18:37
Phil white
Thanks for your help. They are infact et 15. Result.
Posted 27th Nov 2013 at 19:12
7057sam
I ve had 5 different sets over the last year 2 of which you could nt make out the et mark one had the markings jorg's
I also go with the assumption they either et15 shallow or et35 deep centres.
Team rallye,built for track
Rallye dead Sad
Secret Team Astor...
Posted 29th Nov 2013 at 10:18
