Pedro
| Author | Subject: Supercharger |
p-silva21
Regular Location: Lisboa Registered: 26 Jan 2012 Posts: 160 Status: Offline |
Hi guys, I´ve fitted yesterday my supercharger kit that I bought from Rich (aka Fordygti) and when i started it up the idle was at 3k... there are only 2 things that I maybe have to check later that are the TPS and the slimline wiring, but probably the TPS wiring is wrong am I right?Pedro |
fordygti
Seasoned Pro Location: Walpole St Andrew Registered: 07 Dec 2009 Posts: 1,257 Status: Offline |
Should be a problem with the kit as I came of my car working and straight to you. Check all you connections from were you extended the loom. I had a couple of problems at first due to s**te connections. ________________________________________ 98 onyx black 306 Rallye53 Nissan Primastar silver (work horse) 58 black Volvo c30 sport |
Seasoned Pro Location: Parts for Sale section Registered: 04 Dec 2007 Posts: 7,442 Status: Offline |
Check all the boost pipes too.________________________________________ Chris1999 China Gti6 Supercharged [Fun car] >>Project Thread<<2000 Bianca 306 Diesel [Work runabout] |
superchargedblack1997gti6
yep agree with Chris could well be a boost leak!________________________________________ Super high boost Completed, destroyer of gearboxes and 160mph club |
pete-gti
Seasoned Pro Location: Kent Registered: 15 Feb 2009 Posts: 1,297 Status: Offline |
I no this mite sound silly, but your throttle cable ain't some how pull opened? Check all boost connections Go over all your wiring again, Can't be much you will find it:-) |
pete-gti
Do a ecu reset |
stan_306gti6
Moved to Engines. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
p-silva21
Thanks for your replies! Tightened up all the hose brackets again, checked if there was some pipe in wrong position and nothing new... when I return home tonight I´ll check all the wiring too |
p-silva21
Yes Peter I have the throttle bodie full closed I´ll reset the ECU first to see if the problem is the ICV. (remove the ECU during 10 mins right?) |
p-silva21
Thanks Stan, forgot to put the right subject |
Niall
Seasoned Pro Location: Epsom Registered: 06 Jun 2012 Posts: 1,941 Status: Offline |
Remove the inlet and make sure there is no old gasket stuck to both the head face and inlet face. I had this issue, cleaned up both faces, new gasket and was spot on. |
p-silva21
Good point too Niall, tomorrow I´ll check it and let you know |
marco gti6
Seasoned Pro Location: Troisvierges Registered: 09 Mar 2009 Posts: 1,350 Status: Offline |
Nice to see another Portuguese member on here. When i got my car back from the conversion i had issues with the throttle cable as well which would influence the idle. Make The TPS goes from closed all the way to fully opened as mine did not.Bem vindo and get some pics up |
sounds like a air leak and it's sucking in air from somewhere which is letting it idle high________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
p-silva21
Obrigado Marco stupid fail. ECU reset and worked fine Thanks for all your help! |
stan_306gti6
p-silva21 wrote: Obrigado Marco stupid fail. ECU reset and worked fine Thanks for all your help! ![]() Glad it's sorted now. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
