Author Subject: Synchros
osm2121
When i put 2nd gear fast and at high revs, it scratches, if i wait to revs come down a bit it gets in smoothly. I suppose thats the synchronizer "brake" right? So, im planning on changing it, and if its not that expensive, change all of them.
But, are they sold sepparately? Or I have to change the whole Synchro? And where can i get them? Thanks!
Posted 20th Nov 2013 at 12:33
Yes, you're correct, the synchro will be at fault. Yes
Most transmission specialists would be able to do it/source the part I would have thought.
Posted 20th Nov 2013 at 13:37
osm2121
I have just changed the gearbox oil, and miraculously, the scratching on 2nd gear is gone!!!
When I drained the gearbox, the oil that came out looked like grey mud!! And the smell was unbearable!!!
Now the gearbox runs really smooth!! It´s a completely different car now
Posted 26th Nov 2013 at 03:10
I was going to suggest you try this first. Very occasionally, this does work.
In the majority of cases though, it's synchro replacement time.
Glad it's sorted. Smile
Posted 26th Nov 2013 at 07:04
I've also had cases where sloppy warn linkages don't push the selector levers at a decent enough angle so they grind at high revs. First thing to try is box oil though but chances are the synchro on second is getting tired.
Posted 26th Nov 2013 at 07:53
osm2121
Yes, probably this wont last long, but the problem is "temporarily fixed".
I bought the steel gear linkage kit and the short shift from pug1off also. I hope this also help, cause the stick has a little free play
Posted 26th Nov 2013 at 12:06
