Author Subject: side airbag light showing
doon1988
So my side airbag light is constantly lit. Any quick things I can check or do? Got mot on Monday so need a quickie. Can I just take the relay out and if so where is it located?
Posted 16th Nov 2013 at 11:41
Niall
Check all the plugs under the seats are secure Smile
Posted 16th Nov 2013 at 12:45
And if they are, then unplug them and then plug them back in again.
Posted 16th Nov 2013 at 20:06
doon1988
Cheers guy's it's off now. All plugs were in and pretty tight (apart from the yellow ones) anyways disconnected and put em all bk in now the light is off.
Posted 17th Nov 2013 at 11:48
doon1988
Ffs n now they've come back on
Posted 17th Nov 2013 at 15:21
You will need to fiddle around with them so that they are off long enough for the MOT and then afterwards when you get 5 minutes, cut the plugs off and make a nice job of bullet connectors the wires together. This will solve the issue. Yes
Posted 19th Nov 2013 at 08:22
doon1988
Thankfully it passed its MOT yesterday with not even 1 advisory. I am guessing the tester was not too vigilant haha - but yeh I still want to solve it.
I read that apparently the internal Peugeot bulletin about this said to cut off the connectors and solder them together. But some say this increases the resistance and could potentially trigger them. Will look at ordering some of these connectors.
Are they just as easy to fit?
Posted 19th Nov 2013 at 08:48
scotzman
Soldering will not increase the resistance over a plug in connector.
Posted 19th Nov 2013 at 09:08
doon1988
Cheers Scotzman..... I think I will go with the connectors at least it will be easier when/ if I ever put new seats in.
Posted 19th Nov 2013 at 10:03
You need connectors, as that way you can remove the seats easily as you say.
Some decent bullet connectors will solve the problem for sure.
Posted 19th Nov 2013 at 11:15
cully
be carefull if soldering with a mains soildering iorn as the element may leak enough current to fire the airbag!
warm up the iorn then unplug it to do the solder job Wink
Posted 19th Nov 2013 at 12:33
doon1988
Thanks for the tip. Think I will go with the connectors to start with. Sounds the easiest and best option.
Posted 19th Nov 2013 at 12:48
