Author Subject: 306 wing removal help?
Pug bazza
Hello guys, I need to replace my front passenger wing, but I see it looks like it has been riveted in, is there any nuts and bolts other than the rivets running on the top of the wing inside the engine bay, any help will be appriciated
Posted 15th Nov 2013 at 08:57
rivets on the top maybe, bolts along the same edge at top and bottom of engine bay (at scuttle panel and at headlight slam panel), also a bolt behind the bumper securing it to the chassis and also one right up in the top corner of the wing behind the door shut, you'll see it looking up the arch with the liner removed and a torch
to get liner out there's a couple of torx screws in the side skirt base and around the rest of the sides
Posted 15th Nov 2013 at 09:16
ryangti6
Pretty sure there is also a bolt at the bottom that you can access through a hole in the side skirt. You'll also need to move the side skirt a bit at the front to get the wing off.
The bolt holes on the back of the door shut are slotted so don't need to be fully removed just loosened off a bit.
Ryan
Posted 16th Nov 2013 at 00:17
mik
Agreed. Removing the arch liner is a must. Depending on the condition of your car the bolts that bolt upward where the bumper and the wing meet can need plenty of persuasion to get them off or they will snap. A combination of WD40 and heat can help.
Cherry Rallye SOLD
Posted 18th Nov 2013 at 02:23
