Author Subject: BLower, A/C button not working
bezza90
I have had a problem today with the blower on the car. It has stopped working. In addition to this I have rigged the A/C button to control the cooling fans, this has also stopped working.
The lights for both the buttons A/C and Recirculating now no longer come on and the fan cannot be turned on.
I have been looking about and it would appear to point to a fuse No 21, but my car is a phase 3 and I do not have this fuse. The closest one I can see would be No 20 on a PH3, but my car does not have this fuse in (like the picture in the FAQ).
Does anyone have any suggestions on starting points? Am I missing a fuse somewhere? I did check all the fuses last night when it happened, but they all looked ok (it was dark though).
Obviously in this colder wetter weather I would like to get this working ASAP, but am not sure the best way to start, as the only threads I can see either haven't been answered, or seem to point to the Diode in the A/C control panel, but I have no idea yet how to get to it.
Help would be appreciated!
Matt
'00 Astor Grey GTi-6
Team: 'EVO Triangle'
This is a quantum car. I don't know where I am, but I'm going really fast.
PS3 ID: Skaankypuppy
Normally play GT6
Posted 13th Nov 2013 at 10:39
i'm going to go with one of the green relays being burnt out as i've had this a few times exactly and it's always been the relay melting
Posted 13th Nov 2013 at 10:41
bezza90
Ahh ok Thanks. Which relays are they? The ones in the fuse compartment under the steering wheel?
Normally play GT6
Posted 13th Nov 2013 at 10:46
doon1988
This happened to me and it was the blower motor that had burnt out all together
Posted 13th Nov 2013 at 10:50
yep they're the ones. just try swapping them for a known working one or swap them over temporarily as i think there's a couple of matching ones. i don't know which is which though, but worth a try anyway
Posted 13th Nov 2013 at 11:00
bezza90
Cheers Rikky. I'll give it a go.
Normally play GT6
Posted 13th Nov 2013 at 11:58
bezza90
Did the A/C and other button stop working also when you had this issue Doon?
Normally play GT6
doon1988
Not 100% sure. My A/C doesnt work so I never used it... and I havent got my AC adapter bridged for the fans at the moment
Posted 13th Nov 2013 at 12:12
just test the relay, 15 seconds job LOL
if it takes more than 1.85 seconds to pull the relay out, it's stuck in place and burned out
Posted 13th Nov 2013 at 12:20
doon1988
Bit precise there rikky haha
Posted 13th Nov 2013 at 12:28
they do that commonly
failing that send 12v direct to motor and see what happens
Posted 13th Nov 2013 at 12:31
bezza90
Rikky, you would win a prize if there was one! (currently only 1 burnt out relay)
Just after I posted, I went out to the car and whipped out the 2nd green relay in the fuse box and it was burnt just like that one Rikky. Swapped it with the one to the left of it and it works!! (at the current expense of the electric windows and I haven't noticed what else LOL)
Just need to get another relay or two and fingers crossed it will not do it again for some time (hopefully).
Thanks everyone
Normally play GT6
Posted 13th Nov 2013 at 13:02
Any scrappy housing a peugeot should get you another relay Wink
I can imagine pug charging about £20 for one of those Dry
Posted 13th Nov 2013 at 13:05
every 306 i've broke or come across i've kept the green relays for this very reason. they get very hot and sometimes burn the wiring too far to repair! i've got loads if you need some
Posted 13th Nov 2013 at 13:06
bezza90
That would be great Rikky. How much would you be after for two?
Normally play GT6
Posted 13th Nov 2013 at 13:13
£65
each
Posted 13th Nov 2013 at 13:14
Posted 13th Nov 2013 at 14:50
They are £28+vat from Pug, an absolute rip-off. Yes
Posted 13th Nov 2013 at 19:35
I'll undercut rikky as I've got a few too. Plus you know I'm real, rikky is an autobot
Posted 13th Nov 2013 at 20:58
