Author Subject: Indicators / Airbag rotatry thing
drewhughes
Hey guys,
Was planning on removing my dash etc to remove all the sound deadening, half way I thought I cant be arsed with this. lol
But after removing the steering wheel, stalk, clocks etc I bought an aftermarket wheel and started putting things back to together.
Was making sure stuff worked everytime i put something back together.
Everything works bar the indicators. when I turn the ignition theres a click sound as if the hazard lights are flicking on n off, but its in sequence with the headlight icon on the dash flicking on n off.
I havent got the hazard light switch connected either, which I have literally just thought of writing this, dont suppose that has got anything to do with the indicators not working does it?
Also I think I've ended up breaking this on removal as well
which i think is why the indicators arent working?
Can anyone help?
Drew
Posted 27th Oct 2013 at 13:23
pug_306
That's the rotary coupler for the airbag, pretty sure the hazards will need to be plugged in for the indicators to work though :-)
1992 205 GTi6
205 Turbo 340bhp
Posted 27th Oct 2013 at 13:29
rich306
Id consider looking at dismantling the indicator unit, clean up the contact grease inside as it could be causing this glitch.
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 27th Oct 2013 at 14:41
russbez
isnt there an faq for that
My Rallye project thread
Posted 27th Oct 2013 at 15:58
Niall
This. The hazard light switch has to be plugged in for the indicators to work.
Posted 27th Oct 2013 at 17:05
rich306
Ooops my bad for not reading it all right hahahaha
- Top Tip!!!
Posted 28th Oct 2013 at 06:47
Indeed
If you need to drive the vehicle while in this dismantled state be sure to reconnect the hazard warning switch, otherwise the indicators do not work. The connector is the one in the middle.
From Here
Posted 29th Oct 2013 at 01:11
