Author Subject: Can this be the reason?
Pug bazza
Hello guys, when I was putting my engine in, I broke the speedo connector, well pulled the wires out of the connector , so I made do with taping them together it worked fine till today when the wires came lose, that will be sorted but the other issue that has occurred is when braking at junction the car switches off and all the light on the dash appear, but if u quickly put ur foot on the accelerator it starts again, would this be the cause of the speedo wire reason, if anyone could help will be appriciated
Posted 24th Oct 2013 at 17:28
rich306
Hahaha, 'stop start' technology
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 24th Oct 2013 at 17:38
Pug bazza
Lol rich, I'm like oh new invention, I'm glad it happened near home,I was in Bedford and it happened of the motorway lol I was like oh, but any guys have any idea, it didn't happen before just when the speedo stopped
Posted 24th Oct 2013 at 17:42
siburch2000
I had the problem of my speedo stop working every now and again and then it started to get worse. when the speedo was reading 0mph whilst i was driving, as i started to slow down when i dipped the clutch and the engine would stop. i replaced to speedo sender thingy, little white plastic thing? i think and speedo works fine now and no stalling
Posted 24th Oct 2013 at 17:47
Pug bazza
Siburch, It's it the one that has 3 wires going in to it, as that's kind of the same thing happening to me
Posted 24th Oct 2013 at 17:57
It sounds like you bump started it to be honest.
Posted 24th Oct 2013 at 21:46
rich306
I can't see that the speedo wiring would affect the stopping and starting of the engine, sounds like a completely separate issue to me.
I did read right in you saying it would start back up itself?
Or are you manually turning the ignition over again...
- Top Tip!!!
Posted 25th Oct 2013 at 09:58
Pug bazza
If I quickly press the accelerator it will keep going, but if the lights appear and I ain't quick enuf it will just stall
Posted 25th Oct 2013 at 22:11
It sounds more like your ICV is dirty and the engine wants to stall when off the gas.
Look in the FAQ for a guide to clean the ICV, it's a very simple 10 minute job. Yes
Posted 25th Oct 2013 at 23:11
rich306
That's what I was thinking. Smile
- Top Tip!!!
Posted 26th Oct 2013 at 08:46
Pug bazza
Thanks guys il have a look,
Posted 26th Oct 2013 at 11:46
Pug bazza
Sorry to be a pain in the ****, but can someone be a gent or a lovely lady and put me a link up so I can clean the icv, I looked in FAQ but can't Really find it, would most appriciate it thanks guys
Posted 26th Oct 2013 at 11:51
RetroPug
I can't find the link for the FAQ.
However, you simply unplug the connector from the ICV, detach the breather pipe leadng to it, and undo the screws holding it on. Then remove the o-rings and give it a clean through with something, being very gentle with the piston. I used brake cleaner, and gave the o-rings a wipe with WD40.
Then simply put it all back together.
This shows you where the ICV is:
http://www.306gti6.com/forum/showthread.php?id=20477
Posted 26th Oct 2013 at 12:02
m306
Its the vss, mine did exactly the same. Ran fine when the speedo worked but when it read 0mph the car would stall everytime i dropped the clutch. Just get a new vss and problem sorted
supercharged China gti6 - Thu 16th Sep 1999 - sold
2010 megane rs250
Posted 26th Oct 2013 at 17:52
Pug bazza
Thanks retro pug appriciate it, and m306 what's the vss? Thanks
Posted 27th Oct 2013 at 07:55
scotzman
Vehicle Speed Sensor
Posted 27th Oct 2013 at 08:21
Pug bazza
Thanks Scotzman,
Posted 27th Oct 2013 at 08:34
siburch2000
Sorry for the late reply yeah thats the bit, goes in the back below where the exhaust manifold is, mine was under a white bag kind of thing heat prof in guessing!! Ever since i have changed it i havent had the problem any more Smile
Posted 29th Oct 2013 at 18:21
