Author Subject: Replacing crankshaft oil seals
Castor_Troy
Basically can this be done with the sump removed or is it a gearbox out job if the box has to come out think i will wait till i get a lightened flywheel and do every thing at once
Posted 24th Oct 2013 at 17:17
superchargedblack1997gti6
pretty sure it's gearbox out mate!
Posted 24th Oct 2013 at 17:30
Castor_Troy
Thought so what is the seal i have seen mentioned on here that can be replaced with sump off then i have a pretty bad oil leak coming from that area
Posted 24th Oct 2013 at 18:18
that's means you're clutch will prob be out the window soon
Posted 24th Oct 2013 at 18:26
You're best to change the crank seals and the 'hockey stick' seals at the same time.
You need the box off to change the rear crank seal, you need the sump off to change the end cap hockey stick seals. Yes
If you're planning on a lightened flywheel, I would strongly suggest you wait until then. Smile
Posted 24th Oct 2013 at 18:30
Castor_Troy
Ye been kind of waiting on it going but been fine so far Thumbs up Not been too worried about its not as if i need to wait hours on a recovery company turning upBig grin
Its just the oil leak is starting to p**s me offYes
Posted 24th Oct 2013 at 18:32
Castor_Troy
Perfect stan thats what i thought
What seal usually goes the crankshaft or hockey stick
Posted 24th Oct 2013 at 18:34
my crankshaft seal went and fubard my clutch.
Posted 24th Oct 2013 at 19:15
Castor_Troy
Not good man how long ago was that and how much was clutch think i have got a flywheel so best get a new clutch at same time
Whats best just a standard clutch or am i better getting a paddle type
Posted 24th Oct 2013 at 19:21
stAndard clutch fine mate supercharged is ok with them.
Posted 24th Oct 2013 at 19:23
Standard clutch is all you want, trust me. Yes
As for the seals going, sometimes hockey stick ones go other times it's the main crank seal itself. Either way, get them changed along with a new flywheel and clutch and you'll love it. Smile
Posted 24th Oct 2013 at 21:44
