Author Subject: water pipe from rad to thermostat housing wanted
calumsaddler
I am after a water pipe from the rad to the thermostat housing as mine has corroded and leaking Sad if anyone knows where I can get them or anyone who has got one please can you let me know thank you Thumbs up
good to go!!
Posted 22nd Oct 2013 at 17:21
scotzman
Is that the 'Y' shaped hose? if so I have a couple here.
£13 posted.
Posted 22nd Oct 2013 at 17:34
Rich E Forum Admin
If it's leaking from the thermostat housing joint then you may just need a new seal.
Posted 22nd Oct 2013 at 17:49
calumsaddler
where can you get them from ?
good to go!!
Posted 22nd Oct 2013 at 18:07
calumsaddler
and no its the pipe that goes from top of the rad down then to the thermostat housing pal
good to go!!
Rich E Forum Admin
On a GTi-6 / Rallye that pipe has a spur that goes under the inlet manifold and down to the oil / water heat exchanger.
The seal is available from Peugeot. If they can't find it listed for that pipe then the seal from the later lower radiator hoses can be used as it's the same type of joint.
Posted 22nd Oct 2013 at 19:28
calumsaddler
kk thank you pal Thumbs up
good to go!!
Posted 24th Oct 2013 at 17:59
scotzman
if you cant get a seal, this is the hose I have.
Posted 24th Oct 2013 at 18:08
