Author Subject: loosing water
calumsaddler
I am constantly filling my water up in my radiator but there are no leaks or anything that I can see, so I was wondering if it had something to do with my water pump being knackered, the engine runs fine not loosing power or any un-normal behaviour can someone please help im very confused Dunno
good to go!!
Posted 22nd Oct 2013 at 14:13
only 3 things can happen
1 - it's leaking somewhere - tried leaving cardboard sheet under the car after a run or overnight?
2 - it's being burnt - got any white smoke?
3 - both of the above
Posted 22nd Oct 2013 at 14:16
or dangti6 came and took it in the night, because he's the king hoarder
Posted 22nd Oct 2013 at 14:19
calumsaddler
is that bad news if its being burnt Confused and hahaha
good to go!!
Posted 22nd Oct 2013 at 14:22
if it's being burnt it's your head gasket
you say it runs fine -
any misfires from stone cold that clear after a minute?
Posted 22nd Oct 2013 at 14:24
calumsaddler
when it is running its brilliant I work in bulford and live in leeds so nearly every weekend i go back and forth and not a issue and it smokes very little when the engine is cold but I think that's just because its cold outside
good to go!!
Posted 22nd Oct 2013 at 14:30
calumsaddler
and I haven't noticed any misfires when its cold either
good to go!!
Posted 22nd Oct 2013 at 14:32
heaters working ok - no water in footwells, misty windscreen or coolant smell?
rad cap? could be steaming from there
Posted 22nd Oct 2013 at 14:38
calumsaddler
no the heaters are red hot all the time, i've never really had misty windows and no coolant smell either, it is really confusing me unless there's a small leak in the water pipe at the back of the engine near the manifold but I haven't seen any water dripping. Dunno
good to go!!
Posted 22nd Oct 2013 at 14:43
calumsaddler
I didn't think about the rad cap tbh, could it be a air block in the system and its pushing water out of the waste pipe near the rad cap?
good to go!!
Posted 22nd Oct 2013 at 14:45
Top up the cooling system and then bleed it fully. After this, monitor what happens.
Putting cardboard under the car is a good idea to see if you are suffering a leak overnight.
How much are you having to keep topping up with?
Posted 22nd Oct 2013 at 15:06
calumsaddler
there are 3 main bleeding points isn't there. one on right hand side of rad (top), one on the heater matrix and one on the thermostat housing? and I top it up bout once a day but it all depends on when I drive it, if I drive it all day could be up to twice a day I top it up but most I drive it is going to home and back to work on a weekends, few times during week that's it so just depends on when I drive it if that makes sense
good to go!!
Posted 22nd Oct 2013 at 15:13
You're correct about the bleed points. Yes
If you are topping it up that often then you definitely have a leak. Wink
Posted 22nd Oct 2013 at 16:13
calumsaddler
ohh dear looks like I am getting under the car then, ill put some cardboard under for the night see what that does. Do you recommend filling it up and taking it for a drive then put card board under it for the night ?
good to go!!
Posted 22nd Oct 2013 at 16:20
yeah won't do any harm really
calumsaddler
I have just had a look now and I think its coming from the water pipe that leads into thermostat housing, you know where there is that metal clip holding it in, from that bit, I can see loads of orange coolant on the things below and looks pretty new from yesterday so I am guessing its from there looks like its a new one of them lol :/
good to go!!
Posted 22nd Oct 2013 at 16:33
Seems like you found it, let's hope you don't need a new hose though and it's just the seal.
The reason for this is because new top hoses for these cars are no longer available from Pug...
Posted 22nd Oct 2013 at 19:41
calumsaddler
yes I herd there was discontinued witch is guttingSad I wonder if a top hose off any other pug will fit if I cannot find one? but yes hope its the seal lol
good to go!!
Posted 23rd Oct 2013 at 17:27
