Author Subject: 306 S16 does not accelerate in the corners
devilchris
Hello.
I have a Le Mans 306 S16 model year 94.
I'm experiencing a problem.
My 306 does not accelerate in the corners.
For the slow corners there is no problem. if accelerometers fine.
Instead. If I go into a fast corner, with detached and quick entry, mid-corner, at the apex, then at the maximum lateral g-force, even if the accelerator thrust the machine continues with tours blocked (for example at 4000 rpm), without I climb down ... while holding down the accelatore just end the curve and I get perfectly straight starts to accelerate normally ...
What can it be? some relay? sensor? contact?
thanks
Posted 22nd Oct 2013 at 13:58
fuel surge / starvation?
Posted 22nd Oct 2013 at 14:07
devilchris
I did some testing with a full tank!
Posted 22nd Oct 2013 at 14:10
calumsaddler
just a thought could it not be injectors loose wire or something Dunno
good to go!!
Posted 22nd Oct 2013 at 14:15
devilchris
I checked and cleaned all the contacts, the connectors!
Posted 22nd Oct 2013 at 14:22
calumsaddler
does the car seem like it's over fuelling/flooding causing it to bog out or like its starving of fuel ?
good to go!!
Posted 22nd Oct 2013 at 14:34
devilchris
no, it seems as if I can block, with the position of the acceleratorfor example 4000 rpm.
does not seem to miss gasoline, or lacking power to the candlelight.
goes into a kind of stalemate .. the engine revs remain frozen until the machine is perfectly straight ...
if I'm not mistaken, it seems that the problem is only when I turn right. (I'm not sure, I have to do other tests)
Posted 22nd Oct 2013 at 14:42
calumsaddler
I get you now hmm is a weird one I'm just stabbing into the dark, have you looked over the loom just to make sure its not a bad wire or earth something like that might be causing it to trip out
good to go!!
Posted 22nd Oct 2013 at 14:48
Yes, definitely check that wiring, a loose wire (Earth most likely) may be loosing connection under hard cornering one-way.
Posted 22nd Oct 2013 at 15:09
devilchris
I understand the problem ...
the old owner, I do not know why, he replaced the fuel pump with the original in this photo (left)
initially I did not think that was the problem but putting a camera in the tank, the float from the hole, I saw that with simple movements of the machine were rocking the pump.
I have also seen the strange structure in the bottom of the tank, such as a joint.
I then searched for pictures on the web and I realized that the problem was the pump.
I then bought a pump on ebay.uk original:
immediately mounted and problem solved ....
Now I would just replace the pump inside the structure, since I do not know how old this is that I mounted.
Posted 2nd Mar 2014 at 07:55
