Author Subject: Citroen C5 front caliper for rear upgrade?
c_j_m
Just a thought. As the c5s run the handbrake on the front calipers would it be possible to use these to upgrade the rears on the 306? Obviously a bracket would need fabricating to mount the caliper and some modification may be needed for the handbrake.
Should allow both 266 and 283mm discs to be used depending on what calipers are used as both were fitted to the c5 from the factory using the same bracket.
Although I am thinking piston size could be too large?
Posted 22nd Oct 2013 at 08:12
rallyestyle
It's probably possible but really is overkill. Money could be spent in better areas i think Yes
Just Drive It
Posted 22nd Oct 2013 at 11:49
think there's a kit already for a larger rear brake upgrade, seen it on someone's car on here, possibly puglover's years ago. think they used a bracket and s16 front calipers
cituning are the ones who did the kit i was thinking about
Posted 22nd Oct 2013 at 11:54
also:
http://www.306gti6.com/forum/showthread.php?id=143314
just for what someone did, i know they don't use the mechanical handbrake though
