Author Subject: stop light flashes or stays on
calumsaddler
my stop light keeps flashing or sometimes stays on I don't have a clue what it is ive looked for water leaks topped everything up eg oil water power steering and everything else theres nothing wrong with the engine as it works spot on when driving im starting to think it maybe the hydraulic lifter sensor can someone please help as im confused to the max
cheers guys
good to go!!
Posted 21st Oct 2013 at 13:59
brown sensor, bitron, oil sensors from memory.. try them all
Posted 21st Oct 2013 at 14:10
doof
isn't that oil pressure? What does the gauge show at start up?
Might be wise to connect in a mechanical gauge to be sure you're getting good pressure.
Posted 21st Oct 2013 at 14:16
doon1988
Calum I have a similar issue. Ive noticed it seems to happen either after I have just washed the car or when we have pretty heavy rain.
A work mate had a similar issue on a newish civic. Took it to halfords who advised him that they been having a few similar issues and it was just water getting to one of the sensors when people use pressure washers to clean their cars.
Not saying this definitely is the issue but just one to consider. Like yours mine drives fine, sometimes the light flashes on and straight off a couple of times, sometimes it can stay on for several minutes.
Posted 21st Oct 2013 at 14:17
RetroPug
Try and ECU reset and see what happens?
If nothing, try testing/cleaning some sensors?
My old one had this problem briefly and an ECU reset got rid.
Posted 21st Oct 2013 at 14:39
Bitron unit on the inner wing is prob corroded? Whip it out and have a look
Posted 21st Oct 2013 at 14:59
calumsaddler
cheers guys ill have a look now. sometimes it wont come on at all but most of the time is does, it is really annoying
how do you reset the E.C.U do you have to use ignition ?
good to go!!
Posted 21st Oct 2013 at 15:08
doon1988
Just googled and found this:
How to reset Peugeot 306 ECU
Resetting the ECU is a good place to start if you are experiencing strange idle, running or stalling problems. Over time the 306 ECU picks up data from the sensors and 'learns' or adapts to the conditions. By resetting the ECU you will return it to the default settings and remove any 'incorrect adaptations' the ECU has made.
The most common use for this is to reset the Idle Control Valve (ICV) to its default position.
How to reset Peugeot 306 ECU:
1. If you have a standard radio make sure you have the code.
2. Open bonnet and disconnect negative (black) battery terminal.
3. Wait for 10 minutes (maybe time for a really swift cup of tea?)
4. Reconnect battery.
5. Insert keys and turn ignition to second click (all the lights in the dash will light up).
6. Wait 15 seconds or until fuel pump stops priming.
7. Start car
8. Take for a drive covering as many engine loads / rev ranges as possible.
Posted 21st Oct 2013 at 15:16
calumsaddler
cheers I have just wrote all that down, thanks for all the info guys helped me a lot Smile
good to go!!
Posted 21st Oct 2013 at 15:31
ecu reset aka the gti6's biggest myth
Posted 21st Oct 2013 at 15:34
ryangti6
This may sound silly but check there isn't any water in your back lights and that the connections are good.
I put phase 2 lights on a phase 1 before and the loom adapters I used were not of the best quality which caused my stop light to come on, I put them back to normal and never had a problem again so these connections can definitely bring it on.
If you have a water or oil issue the 'stop' light should also coincide with either the water or oil light coming on too.
Ryan
Posted 21st Oct 2013 at 15:42
not surprised you're having trouble with electrics,..
you've no bonnet :O LOL
hope you sort it soon fella!
Posted 21st Oct 2013 at 16:52
calumsaddler
could water in the fogs have same effect as your rear lights ?
haha I had to double look then I was like where is my bonnet, then I realised it was off due to painting i've just woke up Wink
good to go!!
Posted 21st Oct 2013 at 16:56
hazz
Ive had this before, comepne had cable ties the induction kit to the engine loom that runds down the bottom of the radiator, which cause the wiring loom to rub throughon the induction kit, had to repair about 10 wires ! Fixed the flashing stop light though ! Hope this helps ! Thumbs up
Moonstone 1.4... Written off!
Astor 6... SOLD !
New owner of a Moonstone 6 !
Posted 21st Oct 2013 at 17:38
aaron6
Im getting this too. I feel its a dodgy conection on a sensor. When I get time I'll whip it up to Armz's garage and get him to look at it. Its the same though, all fluids are good, car runs spot on. It just flashes on for a couple of seconds and goes again. Peculiar. Smile
Posted 21st Oct 2013 at 18:51
I'm voting this, 99.9%. Yes
Posted 21st Oct 2013 at 22:33
calumsaddler
I think its just a case of looking at all the parts that people have said may be the issue and trying to find it, I hope it isn't the loom it took me hours on end to fit it Angry thanks everyone for the info helped me out a lot, when I find out the problem ill post up what was wrong for future help
cheers guys
good to go!!
Posted 22nd Oct 2013 at 14:01
Temporarily unplug the Bitron unit and run the car...
If the STOP light doesn't flash then you know that's the issue. However, don't leave it like this apart from when testing it as it will mean your cooling fans won't work.
Posted 22nd Oct 2013 at 15:03
calumsaddler
ill try that cheers Smile hope it is something like this its annoying to look at cause its slap bang in the your face lol cheers
good to go!!
Posted 22nd Oct 2013 at 15:06
aaron6
wheres the plug for this?
Posted 22nd Oct 2013 at 15:09
Aaron - It's in the inner wing passenger side, just above the horns.
It's a longish multiplug. Yes
The unit itself is held on with one 8mm nut.
Posted 22nd Oct 2013 at 15:12
calumsaddler
is it like the sensors on the thermostat housing, do you have to use a spanner to get it off?
good to go!!
Posted 22nd Oct 2013 at 15:16
think it just unplugs, it's like a 6-8 pin plug. i've got a known working one at home off my gti6 before i took the engine out and put it in a 205
Posted 22nd Oct 2013 at 15:22
Yep, as Rikky says, it just unplugs no need for spanners. Smile
Posted 22nd Oct 2013 at 16:11
calumsaddler
sweet cheers guys
good to go!!
Posted 22nd Oct 2013 at 16:17
