Author Subject: Steering racks
pugheaven
Iv got a few questions that need answering....
Iv got 3 racks in front of me: A VTS rack, a Gti6 rack and an S16 rack, now my question is how come they all have different lengths steering rack rods/bars
The VTS rack has 277mm rods/bars
The Gti6 rack has 292mm rods/bars
And the S16 rack that came on the dimma has 260mm rods/bars before the added 75mm dimma extensions
Now my question is.... If I fit the vts rack to the dimma with the dimma extensions will it not make the wheels have mega toe in as they are 17mm longer than the s16 length bars?
My second question is how do you remove these bars/rods from the ram section as there is no flats before or after the larger silver portion
Any help or advise will be greatly appreciated Thumbs up
Posted 19th Oct 2013 at 17:25
scotzman
You appear to have an animals foot LOL
Posted 19th Oct 2013 at 15:58
c_j_m
I used standard 306 ones with my vts rack.
To remove, stilsons would be the best bet IMO. Worked fine for me.
Posted 19th Oct 2013 at 16:18
pugheaven
Yep thet will be my dog, he gets in all my pics!!
Cjm so you griped the ball joint part and turned the rod with a spanner?
Posted 19th Oct 2013 at 16:57
eddy_gti6
Grip the ball joint part and turn, should come loose to the right 9f your rod in the pic
Posted 19th Oct 2013 at 16:27
marksorrento205
I wind the rack fully one way then wrap rags around the toothed part (that has now come out of the casing) and lightly grip that in a vice. Then undo on the ball joint as above Smile
Posted 19th Oct 2013 at 16:30
pugheaven
Iv done the non ram end but how do you do the ram end with out gripping it through the boot and destroying the boot?
I know iv got to grip the part where my finger is and was easy enough on the non ram side as I could remove the protective boot but how do you remove the boot on the ram side?
The larger end of the boot appears to be bonded onto the ram eye end bolt lug housing or what ever you want to call it Dunno
Thanks for the help so far Thumbs up
Posted 19th Oct 2013 at 17:23
marksorrento205
It is just a push fit. I use a very thin drift between the collar the ram bolts to and the boot. Bit by bit all the way round. Fitting is just tapping it back into place with suitable blunt drift.
Posted 19th Oct 2013 at 17:49
pugheaven
So that boot has a metal coller bonded to the boot then?
Thanks mate I'll give it a go on the rack I don't need so doesn't matter if I destroy it Thumbs up
Posted 19th Oct 2013 at 17:51
pugheaven
You sir are a superstar, job done!!
Posted 19th Oct 2013 at 17:53
marksorrento205
Glad you are sorted Smile It made me wonder the first time I did one.
Posted 19th Oct 2013 at 18:26
superchargedblack1997gti6
you will love it mate!
Posted 19th Oct 2013 at 18:38
pugheaven
Well it's stripped down into every little component, now just got to clean paint and rebuild before fitting it to the Dimma
Posted 19th Oct 2013 at 19:34
cool
Posted 19th Oct 2013 at 20:35
clen666
Are you replacing any components when you rebuild it?
Wouldn't mind a guide of what's involved once you've finished Smile
Team 'unintentional rat look'
Posted 19th Oct 2013 at 21:21
pugheaven
Na just giving it a good clean, fresh grease and make a new boot for the ram is all I'm doing
Posted 19th Oct 2013 at 21:44
