Author Subject: Head Rebuild?
306xsi
Hi guys,
I’m looking to rebuild a cylinder head I’ve got to put on my car when I change the head gasket. The head came off an engine which had a snapped con rod and consequently 4 of the valves are no good anymore. I’m fairly confident I can do most the rebuild but things like replacing he guides for the bent valves I haven’t got the tools for… would it cost a lot to get done and does anyone know anybody in Suffolk they can recommend to do it?
Thanks for any help,
Will
Posted 16th Oct 2013 at 21:03
rich306
You can buy the tools relatively cheaply enough, You'll need a valve spring compressor:
VSC
That will get the valves out safely.
It's been a while since i've done it but you'll also need a grinding kit:
VGK
The above will help you reseat the new valves into the head.
I'm sure the other guys can advise on what else needs to be done. but the above are stuff you WILL need.
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 16th Oct 2013 at 21:49
306xsi
Thanks for you help Rich. I've got a valve spring compressor. I figured that if the valves have had it new guides would be needed too... I think i'm right in saying they have to be pressed in which is something i'd need someone to do for me?
Posted 16th Oct 2013 at 21:58
Guides are a specialist job, needs doing by an engine shop. Yes
Posted 16th Oct 2013 at 22:02
306xsi
Any idea how much it would cost Stan? Is it on of those things where you're just better off getting a different head?
Posted 16th Oct 2013 at 22:08
Depends on how many guides need changing, but probably around £5 a guide ish, I'm guessing here though.
Posted 16th Oct 2013 at 22:38
Niall
I was quoted £7 a valve to replace them Sad
Posted 16th Oct 2013 at 22:41
Hmm
Not too far out then...
Posted 16th Oct 2013 at 22:49
devere
Where in suffolk are you?
I am too, and I had some valve work done at Coltec in Hollesley. Very good guys
Posted 16th Oct 2013 at 23:02
306xsi
I live near Woodbridge, so not far from Hollesley. Never heard of those guys so thanks for the heads up! Doesn't sound like it will be as expensive as i feared.... a phrase I've rarely used when refering to my 6
Posted 17th Oct 2013 at 23:31
rich306
It gets even better when you have contacts in the industry haha. Thumbs up
- Top Tip!!!
Posted 18th Oct 2013 at 07:54
