Author Subject: Starter Woes
matt16v
Hi everyone,
Had this problem before but thought it was a one off, came back this morning to haunt me. Basically, I turn the key and get all the right lights, crank it and and nothing happens. Not a click or anything. Had a bit of a poke around but still couldn't seem to get her to start. Tried again after 10 minutes and she jumps to life no problems and she's been fine since.
Battery is fine and when it actually turns, starter seems fine. I'm guessing it's something to do with the wiring to the starter.
Anyone got any ideas? Had a look for the starter but can't see it, I'm told it's under the inlet manifold so would assume this has to come out to get at it.
1999 Astor Grey GTi-6 OEM+
Posted 14th Oct 2013 at 18:27
rich306
Starter motor mate, i've just literally changed mine to a diesel one. Sorted it out thankfully.
Smile exactly the same issues you're having.
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 14th Oct 2013 at 18:32
Yep, sounds like the starter. Yes
Inlet manifold off to do it. Yes
Posted 14th Oct 2013 at 18:43
rich306
Be careful you don't split the injector O-rings in the process Wink
Just like i have!
- Top Tip!!!
Posted 14th Oct 2013 at 22:22
Just like i have!
And you disturbed the injectors why ?
Posted 14th Oct 2013 at 22:25
rich306
Took them out removing the inlet manifold... probably didn't to (looking back) but its how i've always done it haha.
- Top Tip!!!
Posted 15th Oct 2013 at 07:23
LOL
Injectors/fuel rail do not need to be touched.
All that needs doing is to undo and remove the supply and return fuel lines from the rail. Yes
Posted 15th Oct 2013 at 08:30
rich306
I know that for next time haha, sorted it all out now thankfully. Cured my fuel leak!
- Top Tip!!!
Posted 15th Oct 2013 at 20:18
sixysix
Bit late I know, but fully agree on the starter being at fault.
Had to change mine at the start of the year and had to do it twice as the first new replacement was a dud Sad
Pretty straight forward to do and took me about 45 mins to swap over.
One of the bolts holding the starter on takes a bit of time to remove due to access but thats it really.
Oh, and get a new inlet manifold gasket as well while you are doing it Thumbs up
Take a look
Posted 16th Oct 2013 at 11:48
raunchz
When you say diesel one, is it one to fit a 2.0 hdi 306? It a lot more powerful for starting the car?
Posted 16th Oct 2013 at 19:05
I would fit the 1.9D Turbo personally if I was still running standard compression. Yes
And yes, it fires the engine over much, much quicker. Smile
Posted 16th Oct 2013 at 20:22
rich306
I second the above... again... LOL
I have been very very very impressed with how quick the engine turns out now that i have fitted this.
- Top Tip!!!
Posted 16th Oct 2013 at 21:52
raunchz
Okay thanks, just looking online i guess the 1.9D is the 1.7kw starter vs the 1.1kw Rallye oem one?
Posted 16th Oct 2013 at 22:24
rich306
Yes
- Top Tip!!!
Posted 17th Oct 2013 at 07:47
are they 'direct' fit? might throw one on my 6 engine in the 205 whilst it's accessible
Posted 17th Oct 2013 at 08:12
Yep, they're are a direct bolt on fit Rikky.
Posted 17th Oct 2013 at 09:58
matt16v
Always felt it didn't turn over great compared to previous cars, have bought a 1.9 starter so look forward to getting it on and having it pounce into life.
Posted 17th Oct 2013 at 22:40
matt16v
Well haven't had it since swapping it over so fingers crossed all will be okay. Got to vouch for the diesel starter motor, she jumps into life now! Really such a big difference, well worth doing (or paying someone to do like I did haha)
Posted 13th Nov 2013 at 00:21
