displaying posts 1 to 2 of 2
Author Subject: GTi6 Idle AFR
jammapic
Hi all,
Been doing a bit of data logging just trying to smooth the last few lumps out in my GTi-6 throttle body setup, before moving on to bigger cams, injectors etc.
Where do you guys aim in terms of Idle Air fuel ratio?
If I connect up the Lambda sensor, obviously it sits at 14.7:1 as measured with my wideband - but it idles like crap there with no ICV, missing and stumbling a bit.
With the Lambda disconnected @ 3.0 bar fuel pressure and my chip wizards mapping I see around 12 - 12.5:1, it idles much better but still the odd stumble and pretty "fuelly" smelling.
If I take a little fuel out and shoot for 13:1 it idles smooth as silk, I can adjust the rpm down to 850 and no issues... but it still feels pretty rich.
Any input?
Ta,
JP
HDI Engine Tuning / Remapping Services - https://www.facebook.com/dervtech
306 GTi-6 Track Car - 200+ hp all N/A!
306 DTurbo Track beasty - 209.9hp - RIP
Posted 7th Oct 2013 at 17:43
24seven
Are you adjusting the ignition timing as well or just the fuelling? From cold it'll want to be a little richer than when it's warmed up - at which time stoichiometric is what you should be aiming for really.
Posted 7th Oct 2013 at 23:00
