Author Subject: turbo oil drain
JWP EFi
Turbo Legend!
there is a blank fitting on the rear of the block-right next to flywheel, can this be used as an oil drain? or would i be better welding a fitting onto the sump?
Posted 25th Sep 2013 at 21:20
Rich E Forum Admin
Yeah that should be fine. It drops straight down into the sump.
Posted 25th Sep 2013 at 21:26
JWP EFi
Turbo Legend!
i know it travels direct to sump, my only worry is that the hole might not be big enough
Posted 25th Sep 2013 at 21:34
fatlapit
Its big enough u should nevrr have the drain emersed in oil
Posted 25th Sep 2013 at 21:36
JWP EFi
Turbo Legend!
i wondered that, but ive seen a few factory turbo'd cars that have drain emersed, saab, vauxhalls, some VAG engines
Posted 25th Sep 2013 at 21:38
fatlapit
If its in the top of the sump it will be above the oil line.
Posted 25th Sep 2013 at 21:41
JWP EFi
Turbo Legend!
thats where i would have done it but if that factory fitted hole will do then i'll just use that. Any idea what the diameter and thread is?
Posted 25th Sep 2013 at 21:45
fatlapit
I modified the plug that u take out with the square drive in it
Posted 25th Sep 2013 at 22:06
JWP EFi
Turbo Legend!
have you got a pic of it mate?
Posted 25th Sep 2013 at 22:13
I'm not 100% sure, but it's probably M16 x 1.5, same as the various blanking plugs throughout the block.
Posted 25th Sep 2013 at 23:28
fatlapit
That rings a bell. Basically i took it out and welded 3" of rod to it then put a 12mm drill through it. Then basically barbed it so the rubber hose wont leak
Posted 26th Sep 2013 at 08:17
dcc
there is a blank round surface a little lower down the rear of the block which is drilled on the turbo blocks, the 16mm plug is for oil level senders when fitted to the rear of the block, though most are fitted to the front.
205 GTI
Xsara HDI
Posted 26th Sep 2013 at 11:58
