Author Subject: XU hydraulic gearbox
eddy_gti6
Is there any hydraulic gearboxs that will fit an XU engine? Cant seem to find anything anywhere. Only the EW gearboxs are coming up when I try searching for a hydraulic box but am sure the EW box isnt compatible with the XU block?
Posted 25th Sep 2013 at 12:48
dcc
mod the standard box for a concentric bearing or use a BE4 casing from a DW engine which has a clutch arm poking out the front, there are hydraulic variants of this type.
205 GTI
Xsara HDI
Posted 25th Sep 2013 at 13:04
allanallen
What the f**ks a hydraulic gearbox?
Facebook
Posted 25th Sep 2013 at 13:33
superchargedblack1997gti6
Think he means hydraulic clutched gearbox?
Posted 25th Sep 2013 at 13:35
Yes, he means a hydraulic clutch. Yes
Posted 25th Sep 2013 at 15:59
Which I believe gti6girl had a conversion on there 6 speed? I'm pretty sure .
Posted 25th Sep 2013 at 17:31
allanallen
Oh LOL not some hydrostatic 'pope mobile' conversion then!Razz
I would imagine the simplest solution would be an aftermarket hydraulic release bearing from AP or similar.
Facebook
Posted 25th Sep 2013 at 19:37
eddy_gti6
I have read into it a little and found the BE3 box is easy to convert to hydraulic. I dont want to run a 6 speed box either
Posted 25th Sep 2013 at 19:42
dcc
yep, off the shelf Concentric bearing from the lines of AP probably do the trick and a few holes drilled in the casing for the hydraulic lines is all that's required.
205 GTI
Xsara HDI
Posted 25th Sep 2013 at 19:48
eddy_gti6
I have an EW box here i could just pull to bits and swap onto the BE3 box. Thats if it can be done like that.
Posted 25th Sep 2013 at 19:56
dcc
that wont be much help as the part of the casing you need is specific to the EW engine, and will not fit the XU.
205 GTI
Xsara HDI
Posted 25th Sep 2013 at 20:06
eddy_gti6
Got a link to the parts your on about dcc?
Posted 25th Sep 2013 at 21:09
