Author Subject: BE3 diff set up
Hawkesfire
Hi i have just got a BE3 6 speed PTS tarmac box and am trying to swap the LSD diff from my BE1 box but when i try and set it up it has too much pre load on the bearings and goes tight.
I think this unit should fit as its the same size as the old unit and wanted to know if anyone has the correct instructions on how to set up the diff as i have searched and it just says the speedo housing controls this, there was a shim in the box of bit that came with the gearbox but even with this removed when i set it up it makes the gearbox tight.
Any ideas?
Marty
206 Rallycross GTI6 SC SHB 425 BHP clutch eater !!!
Posted 25th Sep 2013 at 09:34
dcc
are you using the correct speedo drive housing?
measure the shoulder on them.
205 GTI
Xsara HDI
Posted 25th Sep 2013 at 09:37
Hawkesfire
Using the original one off the BE3 so should be the same?
Posted 25th Sep 2013 at 09:53
dcc
"should" be you say, but is it?
205 GTI
Xsara HDI
Hawkesfire
All sorted the Lsd outer casing was catching the back side of the bell housing only worked this out when i put a shaft in and forced it round and could see the marks on the diff and housing so machined a little off and it all works great so in with the engine on Thursday and we should have it running for Saturday
Posted 1st Oct 2013 at 18:10
