Author Subject: Brake compensator
peugeot96
When lowering a 306, will the brake compensator be stuck open with full brake power to the rear?
Posted 24th Sep 2013 at 21:27
dcc
yup, sure will be.
205 GTI
Xsara HDI
Posted 24th Sep 2013 at 21:33
peugeot96
Strange, it feels like l dont have braks at the rear.
Posted 24th Sep 2013 at 21:37
footah212
The compensator operates as the car tilts forward under braking. If it's lowered equally front and back then surely there is very little difference to how it operates?
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 24th Sep 2013 at 22:41
footah212
Plus I thought when it opens , it releases braking pressure from the rear brakes so as not to lock them. At no time does it put all the braking to the rear .
That's my understanding anyway!
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 24th Sep 2013 at 22:45
JWP EFi
Turbo Legend!
more weight over rear axle means more braking to the rear.
Posted 24th Sep 2013 at 22:49
dcc
you never will have all the braking at the rear due to the difference in piston sizes, and also on most 306's the disk diameter.
205 GTI
Xsara HDI
Posted 24th Sep 2013 at 22:50
footah212
If lowered equally front and back why would there be more weight to the rear Seb?
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 24th Sep 2013 at 22:56
footah212
When it's open it releases pressure from the rear brakes doesn't it??
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 24th Sep 2013 at 22:58
JWP EFi
Turbo Legend!
i'm not saying you would have extra, i was briefly explaining the basics of how it works. Even if front to rear ride height was the same you will or at least should have more effort to the rear as once the beam is lowered you are now acting upon the load compensator hence the above
Posted 24th Sep 2013 at 23:01
footah212
Wasn't having a go bud , was just checking what you were meaning and my understanding of how it works.
Anytime I'm under my car it is fully shut, I assumed it only opens when the weight transfers forward?
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 24th Sep 2013 at 23:07
JWP EFi
Turbo Legend!
i know you wern't having a go. when the valve opens it allows more fluid to reach the calipers (rear)
assuming your compensator is in good condition,ie,not seized, put something heavy in the boot then have a look underneath, you will see whats happening.
Posted 24th Sep 2013 at 23:15
footah212
Will do, it seems my understanding of what that thing does is different.
My theory was:-
In the photo the compensator is closed. The bolt that activates the compensator, is loose at this point.
When the distance between the lhs bolt mount ( beam tube end) and the rhs bolt mount( boot floor end ) increases ,the bolt then opens the valve. This increases the volume of the cylinder in the compensator and relieves braking pressure from the rear brakes. That distance would increase and activate the compensator as the car nose dives under braking hence helping to prevent locking the rears.
Lowering the car or adding weight to the rear would decrease the distance between the lhs mount and the compensator lever thus allowing more travel in the suspension before pressure is released?
footah212 has attached the following image:
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 25th Sep 2013 at 00:15
dcc
No.
As the trailing arm moves up the lever arm is pushed in by the rod, this opens the vakve more to allow a higher pressure to the rear caliper.
205 GTI
Xsara HDI
Posted 25th Sep 2013 at 08:37
footah212
dcc wrote:
No.
Oh well back to braking system training school for me thenLOL
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 25th Sep 2013 at 11:27
