Author Subject: broken topmount bearing effect ride height?
jimmyhackers
as in per title....
basically one side of my car sits about 6-7mm lower than the other.....
it was a lot worse as one of the suspension wasnt fully seated into the hub. this is now remidied but theres still a difference.
ive had a look under the car and cant see anything else a miss.
i notice the side thats lower makes some clunky noises under certain steering and over certain bumps/potholes..... will it be the top mount bearing? can a mashed up bearing effect ride height?
thanks in advance for the advice
jim
Posted 24th Sep 2013 at 01:32
pugheaven
Not enough to change the ride height by 6-7mm, take it that your not using coilovers so I would assume either a cracked spring or one of the shocks are still not located in the hub correctly
Posted 24th Sep 2013 at 19:51
jimmyhackers
nope... think i might buy a set again. phase one original suspension is always shagged
Posted 25th Sep 2013 at 01:36
