Author Subject: Testing ICV supply voltage
lewisdmz
Hi all,
After replacing the ICV with a genuine Magneti one from ECP my idle issues are still present (very occasional stalling, revs bounce up and down slightly). Tomorrow if the weather is dry i'm going to check for air leaks but also want to check that the supply voltage to the ICV is what it should be. My theory is that if it lower than it should be the valve will be slow to react?
I'm guessing you need to test one of the pins vs earth but which one? There's no mention of it in the sensor testing FAQ. Can I just try them all? Complete electrics noob so no idea if this could potentially short something so wanted to check first.
Posted 21st Sep 2013 at 19:06
There are four pins for two solenoids, pins 1 and 4 & pins 2 and 3.
Posted 30th May 2016 at 14:29
barrym
Also try disconnecting the power steering sensor. Blue plug on the HP pipe at the front of the engine
Black Rallye occassional toy
Posted 30th May 2016 at 16:16
as its a 4 wire sensor direct from the ecu you cant test it that easily.
Posted 30th May 2016 at 17:19
cully
Posted 30th May 2016 at 17:45
heliosphan
Cully, is that Peugeot Planet?
Posted 30th May 2016 at 19:41
autodata
Posted 30th May 2016 at 20:02
cully
as welshpug says its Autodata Wink
Posted 30th May 2016 at 21:50
That will give you indication of the health of the component but not the voltage being supplied to it though just so you know.
Posted 1st Jun 2016 at 09:56
