Author Subject: 205 front suspension on 306?
Jim
Greetings,
As the subject says really.
Can I use the front suspension/struts from a 205 on my 306?
Thanks in advance
Posted 20th Sep 2013 at 14:57
dcc
droplink tab is in the wrong place, though otherwise will fit just fine.
however damping will not be great as the car is 300 kilos heavier.
205 GTI
Xsara HDI
Posted 20th Sep 2013 at 16:08
beez_neez_gt
Whilst on the subject, do the ph1 vts struts use the same drop links as the 205, is the drop link point the same?
As said the 205 gti struts are softer which is why some fit uprated bilstein 306 shocks to their 205 for example, they are firmer than the same uprated 205 shocks.
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 20th Sep 2013 at 16:50
dcc
306 uses the same droplink as the xsara and zx.
205 GTI
Xsara HDI
Posted 20th Sep 2013 at 16:58
JWP EFi
Turbo Legend!
to use 205 dampers on the 306 you will have to weld a bracket on to the existing lug so you can fit the drop links, you may also have to reposition the brake pipe bracket iirc otherwise it will foul the drop link
I had a set of 205 Koni adjustables on my old HDI and they were fine, although i first fitted the 205's 30mm springs and my car was more like 70mm lower with its heavier engine, i later fitted selex springs
I still have these Konis if your interested
Posted 20th Sep 2013 at 22:01
beez_neez_gt
Is it ok to weld on a shock after its been filled up with fluid or air etc ?
My vts shocks have a flat connection bit not L shape like above.
Pug fee`ver,
Posted 20th Sep 2013 at 22:32
JWP EFi
Turbo Legend!
It's not ideal but it worked out ok, we wrapped the dampers with soaking wet rags to stop heat soak.
As for the brackets, we looked at different ways of doing it and this was what we came up with, the drop link nuts were awkward to tighten at first but a 16mm ratchet spanner made it easy
Posted 20th Sep 2013 at 22:43
allanallen
You can remove the insert on alot of dampers making welding to them safer
Facebook
Posted 21st Sep 2013 at 17:16
