| Author | Subject: Radiator help |
Pug bazza
Regular Location: London Registered: 04 Apr 2013 Posts: 195 Status: Offline |
Hi guys, yesterday I was parked up when I heard explosion, after driving I realise my temperature gauge heading to the red, so I stopped let it cool down and drove it home, in the morning I opened the expansion tank to find no water in it, so I filled it up with water and it started to leak from the hose that goes to the back of the engine, now the issue I have is that when I was replacing the engine I did try to disconnect the pipe from the radiator but it wouldn't budge so any suggestions on how to get it off also I'm curious to find out what could causes it to explode as I had drivers it for long while and all temperature was fine till at standstill it happened, when the engine is cold and I check the water each morning, there is pressure in the expansion tank when removing the cap so would this been the cause of it as it was pressurised thank you any help appriciated |
dcc
Senior User Location: Wales Registered: 24 Feb 2009 Posts: 502 Status: Offline |
remove the clip.headgasket is probably on its way. ________________________________________ 205 GTIXsara HDI |
jimmyhackers
Seasoned Pro Location: birmingham Registered: 14 Jun 2011 Posts: 1,302 Status: Offline |
heat and wigglling gets most hoses off. and yeah sounds like a hg issue ![]() ________________________________________ the world is changed by people in sheds |
Pug bazza
I think it head gasket I fixed hose so no leaks I drove it and after 2 minutes, it went in red, I had to stop let it cool b4 going home, my old man reacons head gasket to as when the pipe blew it was on red b4 I realised and stopped, I took the car on a longer drive and the temperature was on 90-100 but not on the red, I was also thinking it might be air in the system as a last precaution, can anyone tell me how to take air out if the system thanks guys |
mik
Seasoned Pro Location: Kent Registered: 17 Feb 2011 Posts: 2,100 Status: Offline |
See reply in your other thread here: http://www.306gti6.com/forum/showthread.php?id=157472 ________________________________________ Cherry Rallye SOLD |
stan_306gti6
If the HG wasn't already going, I'm pretty sure that is what the fault will be now. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Pug bazza
Lol oh stan, I really don't like my peugeot my French lover keeps breaking my heart but but but I CAN'T RESIST LOL, I'm going to bleed it this morning so all the best if I get stuck i will coming back here |
