| Author | Subject: PAS removal |
Niall
Seasoned Pro Location: Epsom Registered: 06 Jun 2012 Posts: 1,941 Status: Offline |
Removing my PAS pump. Does anyone know the new belt length? Its a AC model so i should be ok with just going right over the alternator and back down yes? |
Seasoned Pro Location: Southwark Registered: 18 Jul 2010 Posts: 4,865 Status: Offline |
Mentalist! ![]() Wouldn't want that one a road car! ________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
Niall
Who said I won't be running pas? Lol converting to an electric setup to make room for my charger. |
With what tensioner? As the auto tensioner won't work with the belt running like you want to above,and the Rallye non-aircon tensioner won't either Or are you keeping aircon pump? ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
Niall
I was going to keep the air con pump for the time being until I can afford to get a rallye set up. Sure I had a quick look and with the air con pump in place, the auto tensioner should still work or am I just being a retard? |
Ahh i see what charger you got then?________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
Niall
Eaton M60. Going down a completely different route to the typical Rotrex one |
IvayloPavlov
Regular Location: Sofia,Bulgaria Registered: 06 Aug 2012 Posts: 265 Status: Offline |
Niall wrote: I was going to keep the air con pump for the time being until I can afford to get a rallye set up. Sure I had a quick look and with the air con pump in place, the auto tensioner should still work or am I just being a retard? Yeah if keeping aircon pump auto tensioner will work As this is how you tension the aux belt when you relocate pas pump to aircon pump position when fitting itbs etc If the aircon pump has the same size pulley as the pas pump and is positioned in exactly the same place as the pas pump is when its relocated you want a 6PK1103 Aux belt ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
Niall
AH nice one cheers mate |
IvayloPavlov
@Niall did you find correct belt? |
IvayloPavlov
IvayloPavlov
