Everything works when cold and the pump primes etc when hot but just doesn't want to start.
Any ideas?
Our thoughts turned to Coolant Temp Sensor or Crank Sensor?
Cheers all
| Author | Subject: Hdi starting problem |
maybe
Regular Location: Leicester Registered: 15 Jun 2009 Posts: 385 Status: Offline |
My mate has a 2.0 Hdi that starts perfect when cold. But once it gets warm/hot it doesn't wan't to start.Everything works when cold and the pump primes etc when hot but just doesn't want to start. Any ideas? Our thoughts turned to Coolant Temp Sensor or Crank Sensor? Cheers all |
stan_306gti6
Possible air leak.I had this years ago on a D Turbo engine. There was a tiny crack in the fuel filter housing. It would start perfect from cold but then once it was up to temp and the crack opened as the housing expanded it buggered about. Does this engine run ok when hit and just won't start again if you switch it off? ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Get it plugged into proper diag stuff, thatll tell you a lot straight away.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
maybe
That would be easy! |
mechanical_repairs
Get it over to me, I will take a look you huge penis. When I get back next Thursday.Carl ________________________________________ C.G.Cars of Leicester, Peugeot/Citroen/Renault specialist Tel: 01162 624498/07799 405184 WWW.CGCARSLEICESTER.CO.UK36 narborough road south, Leicester LE3 2fn MOT station now open, tests £35 with a free retest. Recovery available with a recovery unit, for those not so local jobs Also offer the loan of a free courtesy car 306 dturbo |
![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
martinh
Seasoned Pro Location: Bideford Registered: 08 Dec 2006 Posts: 1,274 Status: Offline |
I had this on my scudo hdi. Turned out to be a knackered injector which was highlighted by a leak off test.May be worth a try? |
maybe
mechanical_repairs wrote: Get it over to me, I will take a look you huge penis. When I get back next Thursday. Carl I've told him carl but he's above help in the manual sense. |
