Author Subject: ac to nonac rad fan conversion?
jimmyhackers
ive removed the front ac heat exchanger and want to remove a noisey rad fan.
the first one to come on has shot bearings and is noisey. the second fan to come on is fine.
is it as simple as remove both fans bin the s**t one and put the good one in the first ones place and plug it up?
are there different connections between the two?
does the system need to have the second fan plugged in to work properly?
thanks in advance for the advice
jim
Posted 1st Sep 2013 at 00:40
You need A turbo diesel non ac fan if you want two.
If you want single fan just get a non ac loom from a petrol engine, i.e rallye
Fans themselves will plug in, speeds wont work properly with one missing.
Posted 1st Sep 2013 at 07:15
jimmyhackers
thanks for the info.....
so your saying even if i change the loom my fans still wont work properly with only one plugged in?
or if ive misunderstood and changing the loom will make a single fan work properly....
can i not adapt my exsisting loom......
i.e. bridging the looms second fans connector pins straight or with a resistor etc? has anyone done this before?
thanks again for the help
Posted 1st Sep 2013 at 17:29
The fans run in series on the low speed setting, therefore if one isn't plugged in neither will work. Wink
Posted 2nd Sep 2013 at 08:34
jimmyhackers
hm.....so bridging two pins on the unused fan port may correct this?
Posted 2nd Sep 2013 at 13:42
just do it properly.
Posted 2nd Sep 2013 at 13:46
Much simpler to find a single fan with its wiring and plug it into a radiator temp switch that you'll have to purchase.
It will cost you bugger all compared to the time it will take to get the other work correctly
Posted 2nd Sep 2013 at 19:27
scotzman
I have a Rallye fan in the shed SmileWhistle
Posted 2nd Sep 2013 at 19:31
jimmyhackers
i need a the loom and the sensor apparently Smile
anyting your willing to to trade for if you have them?
i have a fair few 306 things lying around
Posted 3rd Sep 2013 at 23:35
