| Author | Subject: Is this right? |
Pug bazza
Regular Location: London Registered: 04 Apr 2013 Posts: 195 Status: Offline |
Hello guys, I seem the coolant bleeding thread already posted, but just wanted to clearifiy few things, I bled the coolant system it was heading to 90-90+, when stationary but when driving it came down, but the end result I got when stationary was 83-85 would this be correct, there was air in the system as bubbles was appearing from the bleed valve on rad when bleeding, thanks |
stan_306gti6
The car has an 83 degree stat so it shouldn't drop below that when up to temp and driving. It sounds like you did it correctly. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Pug bazza
Thanks stan so now should drop below or rise more than 83 when stationary thanks, but when driving it would drop below I imagine |
Pug bazza
Shouldn't drop below 83 or rise more than 83 when stationary,sorry last post it come up with 'SHOULD' |
RetroPug
Surely it will rise until the fans come on at 110ish if left stationary as the coolant isn't being cooled by anything if you're not moving and the engine is still getting hotter if it is still running.________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
fans come on well before 110, stop light comes on at 110!! from memory 92 is low speed 101 is high speed.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
RetroPug
I hear and feel them when high speed comes on and remembered it was 100andsomething but yeah just realised they obviously do come on before the red.Think my memory's just patchy. Thanks. ________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
stan_306gti6
On a twin fan system the low speed fans come on at 97 and the high speed kicks in at 107...If the vehicle is being driven, the temp should be around 83-85 on the gauge, once you're stationary then it will obviously go up. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
scotzman
Seasoned Pro Location: Dundee Registered: 24 Jun 2011 Posts: 1,408 Status: Offline |
My temp sits about 80, I thought this was low so changed the thermostat..still 80, replaced the temp sender and no change.________________________________________ '90 1.6 205 GTi, '98 306 GTi-6 |
stan_306gti6
It may show 80, but that is correct as the gauge isn't exactly spot-on accurate.________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Pug bazza
Thanks guys help much appriciated |
RetroPug
Hm wasn't far off then.________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
